2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I have a 1953 factory replacement 235 in my truck. the alignment sleeves are missing, thus bad vacuum leaks. Does anyone know 1) where to get them, or 2) what the dimensions are so I can make a set out of locally obtained tubing? Thanks in advance. Ed | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Google Chevy 235 intake/exhaust alignment sleeves. Several of the usual venders sell them. ðŸ›
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Use pieces of exhaust pipe with a slice cut out and trim the length to fit the hole. It takes a little cutting and trying, but the sleeves don't seal vacuum. They only align the manifold so the gasket can do its job properly. Jerry
| | | | | Joined: Feb 2013 Posts: 613 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 613 | Ed, I actually just installed my intake and had the same issue as you. I was able to use a or I believe it was a 1” copper coupling cut to the correct length. As Jerry mentioned, there for alignment purposes only. You mentioned vacuum leaks. Make sure the intake/exhaust manifold are not warped. Hopefully just a thicker gasket will solve your issues. Good luck, Jim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I got a set at Classic parts a few months ago.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2014 Posts: 4,481 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,481 | Just use a spring steel piece from a wooden crate strap. It is likely already the right width and once you get it cut it will stay in the hole without any work...remember it wants to be straight and flat.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hmmm . . . . [five ? rings - listed as “seals” ?] Ask the eBay seller about the number of rings, before you buy. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Right on the GM package it says , seal . https://i.postimg.cc/SNVCt2Z5/235-Manifold-steel-ring-seals.jpgTake it up with GM........I had nothing to do with it . GM decided to package them ( 5 ) to a package ........why ? George '54 3600
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Since a stovebolt engine only has three intake ports to deal with, why do the resto-ripoff guys sell the sleeves six at a time? Price gouging, or just ignorance? Jerry
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I have a 263 straight eight in my 37 Buick and it cracked two exhaust manifolds which are getting hard to find. A friend that ran a small block Chrysler in his circle track car which isn't an engine that every FLAPS carries header gaskets for clued me in on red high temp silicone. I then used neither alignment rings or gaskets which I figured might let the manifold "creep" between hot and cold. That was twenty years ago and still holding with no leaks--exhaust or vacuum. The manifold and head MUST be surgically clean before applying sealant. [img]https://i.postimg.cc/Rq34bd8V/Pont-heater-Buick-sealant-003.jpg[/img]
Evan
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Dang, Evan. Now I'm not saying that you are crazy, but it is crazy to me that the high temp silicone would withstand the exhaust heat. But then, since there is no gasket there, the silicone got squished pretty thin so it can't really get blown out. It reminds me of how anaerobic sealant works on sealing the 2 halves of 2-cycle outboard case. It must be squished very thin to work. It also has to withstand some high heat conditions.
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | There are GM NOS ( 3 ) intake manifold sleeves on ebay right now @ $12.00..........they are in excellent near mint condition . Fits 1950 to 1962 ALL ( ex.216 ) Go to ebay & in the search box.......type........3835506 PIC https://i.postimg.cc/bvhKcZLf/3835506aa.jpgThey have the correct factory specs - correct thickness - the correct spring action & the correct depth & the correct I.D. & O.D. when closed and are made in the U.S. A. Certainly better then out of spec homemade . So , why buy made in china fake repro's . Here's a GM NOS set that sold on ebay last month for $7.00 . PIC https://i.postimg.cc/j5br9XmN/3835506e.jpgGM NOS for less then chinese fake junk . George '54 3600
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I put 23K trouble free miles on a 216 sans those rings..... When I R&R'ed the head the originals were toasted beyond reuse so I installed the manifolds without them as I really wanted to see if the engine would run. It did and the need never arrose (?) for said rings.....
I did install those rings on my 235, haven't put any miles on it yet but it's getting oh so close...
I don't believe those rings will stem an intake or exhaust leak, IMHO they are to keep the gaskets inline whilst installing the manifolds, IMHO ofcourse LOL... | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Getting an assembly as heavy as the intake/exhaust manifolds perfectly aligned so the gasket seals correctly is a matter of being lucky, not necessarily good, in most situations. It's a lot more likely to happen with those three little pieces of tubing in place. The suggestion about using a piece of steel crate banding strap is one I'm definitely going to remember! There's also a set of dual-diameter rings available to make a 216 manifold fit a 235 head, or the other way around. Jerry
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Yeah, Jerry, I'm not good, lucky, or smart so Buick did me a favor and used dowl pins at the front and rear of the exhaust manifold rather than bolts---kind of makes alignment dummy proof.
Evan
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | Like Jerry said, getting the gaskets in place without the sleeves is quite a task. I have had issues with it in the past and want to get this thing running properly. Thanks for all the suggestions. I may try the banding iron method if I can get my hands on a piece. Ed | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | | | |
