5 members (dt235sd, klhansen, 2-Ton, 52GMC35424JD, Hotrod Lincoln), 79 guests, and 3 robots.
Topics128,049
Posts1,055,665
#131126 03/13/2003 5:31 PM
I am just about to start plumbing in new disk brakes on my '68 Suburban. A previous owner added a power booster to the stock drum brakes. I don't know the vintage of the donor parts. Since I have to redo all the lines in the front, would it make sense to change from the existing 3/16" lines to 1/4"? I understand that disks need more volume to operate properly.
Paul
#131127 03/13/2003 9:23 PM
Use whatever the size is on the wheel end, that will be what it is designed for. Lines that are too big make the pedal feel spongy.
Paint & Body Shop moderator
