| | | Forums66 Topics128,127 Posts1,056,671 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 23 New Guy | | New Guy Joined: Jan 2016 Posts: 23 | Looks like my over drive needs a new tail shaft bushing. There's a drip drip going on and the play seems too excessive. Can this be replaced without pulling the transmission? Will the miller 6957 tool pull this bushing? What about other bushing pullers? Thanks Greg
1959 Apache btw
1959 Fleetside Apache Deluxe Shortbed
| | | | | Joined: Apr 2005 Posts: 2,100 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,100 | I believe you would create more work for yourself trying to replace the bushing in that manner. There is not much space to get a puller in there. The more important issue would be installing the new bushing in place. It is very thin and can get distorted easily, in which case the driveshaft yoke would bind up and you would have to disassemble everything anyway. Even when installed in a bare case, they tend to "shrink" and sometimes need to be cleaned up. Fred
| | | | | Joined: Jan 2016 Posts: 23 New Guy | | New Guy Joined: Jan 2016 Posts: 23 | Thanks Fred, So out comes the trans. There's a shop not far from me that does these. I guess I'll take it to them.
| | | | | Joined: Apr 2005 Posts: 2,100 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,100 | They should replace the solenoid seal, OD shifter shaft seal, and the rear seal while it is out. Fred
