| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 34 | Guy's I looked for quite a while in here for the answer to this so sorry if its been covered too many times - but I can't find answer here in the forum - I have. 49 3600 and would like to improve breaks - convert to disk system. The last time I looked and asked you guys about 2011 there were no off the shelf kit's has this changed . Are there any on the market now? | | | | | Joined: Jul 2015 Posts: 18 New Guy | | New Guy Joined: Jul 2015 Posts: 18 | Hi,
I swapped my front axle out of my 1950 3600 with a doner axle from a 1950 3100. Axle is same except the spindles\king Pins a bit smaller, which allow you then to install disc brakes from most any kit then | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Using 1/2 ton axle you can't use 8 lug wheels, and you have reduced the capacity of the truck. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Yes, mine is now a 1/2 ton long bed as well...!
1/2 ton axle in the front.
Of course, after you swap the front axle, you're going to have to swap the rear end too, if you want the same bolt pattern on all 4 wheels.... had I found the kit referenced above prior to my swap, I would have gone with it instead, and kept everything else stock.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Jun 2016 Posts: 11 New Guy | | New Guy Joined: Jun 2016 Posts: 11 | I've been searching, this is what i'm going to do, Front The Hollister Road Company Disc Brake Conversion was designed to be used on 3600 and 3800 Chevrolet Truck from 1947 to 1959 with single rear wheels. There is a difference between front wheel hubs on single rear wheel and dual rear wheel trucks and both can be 8 lug. Rear I'm getting a 73-87 14 bolt FF And putting the Great lakes Offroad LLC GM 14 Bolt Full Disk Brake Kit w/ E-Brake Calipers. and a late model GM master and Booster. I've decided to do all this because can't get rear parts for 48 3600. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You might not find drums for your original rear, but what else can't you find? I've found everything I need, and many others have rebuilt and still run the original Eaton. Even the 4.10 gears aren't that hard to find used.
I do like the 14 bolt, but it's not a necessary swap. Have you looked for disc brake brackets for the old Eaton? Pretty sure they exist in the 4x4 aftermarket. | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | There are rear disc conversion kits a available for your truck. I've seen them for the rear of a 1 ton. You would be able to keep your stock axle if your so inclined. Everything other than drums should also be obtainable for a 3600 1949 gmc 1-ton | | | | | Joined: Jun 2016 Posts: 11 New Guy | | New Guy Joined: Jun 2016 Posts: 11 | The reason I want to change is the fact that the Eaton rearend can't be geared were I want it, 3:55'3:73, | | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | Just so you know we do have a kit for the Dually front hub. and the single wheel front hub. The late model rear axle is a good choice. You get disc an da better choice of gearing DRW Kit | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Discs eliminate a lot of adjusting on Huck brakes.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The one thing they did not mention is the proportioning valve or master cylinder with one.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can buy a master cylinder and proportioning valve from some of the vendors. Just look for one for the 1/2 ton. Same cylinder piston as the 3/4 and 1 ton.
Fred 52 3600 69 C-10
