0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I have searched my usual places and can't find this block casting number 6848660. The ad says Canadian full pressure 235, but I can't confirm anything about this except there is a picture of it on marketplace. The head number is 3701887 that shows as a low pressure 235. Anybody know what the block is??
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | the head number 3701887 is also used on full pressure 235 engines in 1953 model years in Canada, both my GMC and Chevy trucks have that head. the block i have under that head number is 5843350 can't help you on the 6848660 number -s
| | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | the head number 3701887 is also used on full pressure 235 engines in 1953 model years in Canada, both my GMC and Chevy trucks have that head. the block i have under that head number is 5843350 can't help you on the 6848660 number -s I have the same casting #'s as you. https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1264062/2.html I have a couple posts on page 2 and 3 in this thread about it.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | The 1887 head is 53-55 stick motor. I don’t have anything on the block number.
Mike
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | hi MikeE, if possible can you post a photo of the block casting number? along with any other unique markings on the block or whole engine. thanks -s | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | It looks like 6848350 or 6843350 to me, but the first two numbers are eroded and barely legible.
Professional Novice
