2 members (49 panel, Hotrod Lincoln), 42 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#1310597 05/13/2019 2:08 PM
I have searched my usual places and can't find this block casting number 6848660. The ad says Canadian full pressure 235, but I can't confirm anything about this except there is a picture of it on marketplace. The head number is 3701887 that shows as a low pressure 235. Anybody know what the block is??
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
2 Offline
the head number 3701887 is also used on full pressure 235 engines in 1953 model years in Canada, both my GMC and Chevy trucks have that head.
the block i have under that head number is 5843350
can't help you on the 6848660 number
-s
-s
I have the same casting #'s as you.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1264062/2.html I have a couple posts on page 2 and 3 in this thread about it.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
The 1887 head is 53-55 stick motor. I don’t have anything on the block number.
Mike
2 Offline
hi MikeE, if possible can you post a photo of the block casting number? along with any other unique markings on the block or whole engine.
thanks
-s
https://scontent-ort2-2.xx.fbcdn.ne...3280a0d76054427f0f974811&oe=5D758E52 If this doesn't work, try facebook market place appleton wi. search chevy 235
1946 1-ton Panel
It looks like 6848350 or 6843350 to me, but the first two numbers are eroded and barely legible.
Professional Novice
