3 members (TexasJim50, Peggy M, TexasA&M48Truck), 105 guests, and 6 robots.
Topics128,094
Posts1,056,058
Members48,433
OK so you have your specially ground drill bit or a spot weld cutter. I've only used the first one with fairly good success. Certainly the objective is to not intentionally drill past the top panel and try not to disturb the bottom in order to separate the panel in question. So...is one better than the other or should I say its only as good as the individual operating the drill.
Seriously, is one better than the other or is there an occasion where both should be at ones disposal?
I've used different methods as of late. My cowl panel was done with an old Snap-On center pilot drill bit spot weld cutter. Didn't bother me to weld up the center 1/8" hole on the panel that was staying. Comes in different diameters. As far as I'm concerned, easier to use than the center spring loaded awl type that Mac is selling these days.
When I did the wheel wells on the Suburban, so much metal was going to be fabbed and replaced by me, that I took a disc sander, sanded the spot welds until thin, then used a spot weld splitter ( a hard steel bar with a knife edge) and sheared off the rusty pieces.
I haven't used a drill bit to separate spot welds for a long time!
A spot weld splitter...I need check them out for sure. I have used a pneumatic chisel on occasions for stubborn stuff. Although it will do some damage real quick! All of my bits have been used up and trying to decide if I should buy more or opt for cutter style.
5 Online: Content
I have used a spotweld cutter before, but it dulled before I was half way done with a couple hundred spotwelds. I had an issue with getting the center to stay in the middle of the spotweld also.
I have been using a 3/16" drill bit since giving up on the spotweld cutter. The drill bit seemed to find the center of the spotwelds by itself. The 3/16" bit is plenty big to get all of the spotweld, and was just the right size to be able to get the bottom metal red hot for TIG welding the spotwelds back in. My old spotweld cutter made a huge hole, requiring too much welding, threatening warping of the panels.
I purchased a set of Blair spot weld cutters and had great results. They are a little pricey but the do work great. Bill
1937 GC
Where did you find Blair cutters. Maybe one can ignore the investment if the results are favorable.:>)
Internet..type in Blair spot weld cutter. Also called rotabroach.
1937 GC
I like the Rotabroach as well. I have a couple os set of them in assorted sizes, including an older set that was made by Hougen, which was the original manufacturer before Blair bought them out. Any welding supply store should carry them, too, plus I know that Snap-On sells them under their Blue Point name. Classic Industries also sells them.
Bill Burmeister
Thanks fellows.
Snap On has gotten cheap with their stuff. The older cutters are the Blair/Rotabroach style with a centering drill bit.
Here is the older Snap On cutters and the splitters.
I checked out Blairs website. More than likely will purchase a Spotweld cutter kit 49.05...reasonable. Splitters as well...maybe Harbor Freight?
Fox Offline
I use a Blair as well and it performs very well. One thing I’ve learned is that the awl type end isn’t good enough to keep things in place on any spot weld cutter I’ve used. I now use a regular drill bit, just kiss the spot weld so it creates a crater for your awl to ride in and then spot weld cut away. It works so much better this way for me.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
5 Online: Content
Great advice given of the better type of spotweld cutters.
I just hope that I stick to my guns about never buying another truck which requires the use of one. smile
We'll see.
I saw somewhere that Eastwood also has the splitters.
https://www.google.com/search?q=spo...V3pBs4Q_AUIDygC&biw=1600&bih=757
In my experience the tool you use will largely be determined by which panel you are saving, what access you have to either side, and how well you and the tool work in harmony.
If you are facing the piece you wish to save, and the lower panel is essentially a throwaway, then simply use a drill bit the same size you would select for plug welds, and drill out the spot weld. When you place the new panel beneath and clamp it up, the hole you drilled in the top panel now serves as your plug weld hole.
If you are saving the lower panel, and throwing away the top, you can use whatever works best for you. There are many ways to accomplish the same thing, but if you are not proficient in using one method, try another. I think each method has it's faults, so pick the one that best suits the area you are working.
The holesaw type cutter typically cuts like any other holesaw does, and once the teeth start to cut a "channel", it is difficult to see how far along you are progressing. At the point the cutter reaches the second layer, which is where you would want to stop, if there were a bit of rust between the two panels and your cutter had enough speed, you would have a visual indicator in a wisp of "rust smoke" that is seen coming around the cutter. It is here that, even though some moderate speed is needed to produce this indicator, light pressure is also needed (better classified as "restraint") so that you don't go through too far and damage the second panel. In my case, I found myself going through too far, and would either need to repair the deep channel I just cut in the second layer, or would have to weld in a circle to repair the gaping hole I just left. Needless to say, I no longer use this method, and gave the cutters I did have to someone else that hopefully is having better luck with it than I did.
Some of the cutters have a spring loaded center punch, much like a machinists roto-bore. Even with an initial center punch used in the middle of the spot weld, These cutters have the misfortune of slipping off center, and many people will simply drill a 1/8" diameter hole, either partially or all the way thru, to prevent the cutter from walking about. I'll stop here and offer a generalized thought. If you have difficulty filling an 1/8" hole in a piece of sheet metal with your welder, you will likely have problems with the pilot drill method, and perhaps should try one of the other methods.
I think the Wivco cutters will work better than the hole saw type, in that they mimic an end mill, so the cutter is relatively flat on the bottom. This should give a less aggressive cut, a plus for people like me who may have a problem of leaning too hard on the cutter. The open flute design will also allow you to better see what is going on than the holesaw type, which obscures everything. It does use the pilot bit, so if that is not an issue (see above paragraph), then this is a good choice.
[img]http://www.tonsoftools.com/images/Wvth25000.jpg[/img]
The blair cutter is available in either the spring loaded version or the pilot bit version, I think these are a more aggressive cut than the wivco, especially since the cutting surface is extremely narrow, so it may be more likely to pose the cut through problems I described initially.
[IMG]http://cdn3.volusion.com/uo9gz.acro2/v/vspfiles/photos/13224-2.jpg?1470814969[/IMG]
A rounded burr grinder is also a good method which should somewhat limit the damage to the (throwaway) panel to just slightly larger than that of a spot weld cutter. The downside is that these also come with little tiny slivers of metal that are a pain when you get them in your skin, so it would be advantageous to address these with a vacuum cleaner/foxtail and dust pan on occasion to keep the issue at bay. A pair of work gloves come in handy as well. Keep some duct tape handy to pull out the slivers that sneak by.
[img]http://static.wixstatic.com/media/7...jpg_srz_500_500_75_22_0.5_1.2_75_png_srz[/img]
The last method I'll discuss is the one that I use because I don't play nice with the holesaw type. I tend to inflict enough damage that I'll need to fix hole saw size holes through the save panel, or at least deep grooves. I use a 3" cutoff wheel with a 1/16" thick cutoff disc and use the tool to grind away the spot weld. I find for myself, it offers a less obstructed view of any of the methods listed, and with the proper speed (fast), will give you an indicator in the discoloration of the top layer (blue or darkened) usually before you have even broken into the second layer. Basically the metal is heating up and as it starts to get thin, it heats up more quickly and shows this via a color change to blue. The color change back to bright silver will indicate you have reached the second layer, and act as a guide where to not grind anymore (the bright area) and where to grind, the blue/dark circle surround it. The disadvantages with this method, are the top panel is basically useless now, you will need good eye protection (more so than the holesaw type cutters), and due to the grinding particulate, will need to use a respirator/mask to prevent you from hocking up black globs shortly afterward. I usually get a 3M or equivalent paint respirator, as the typical dust masks only serve to fog up your safety glasses, and as is evident upon the removal of the dust mask, they don't work all that well. A paint style respirator exhales to the sides, away from your safety glasses, and typically conforms to your face much better.
Grind pattern visible:
[img]http://i5.photobucket.com/albums/y167/rmccartney/1955%20Chevy%20Wagon%20Restoration/HPIM5779.jpg[/img]
Or better yet, the video instructional method....
That should give a brief view of both the good, the bad, the ugly with most of the methods, now it will be up to you to figure out which one works best for you and best for the situation at hand
5 Online: Content
Great post, Robert!
You provided the ultimate correct answer to the question.
One should use any and all methods available which work best for them, and for the specific application presented to them.
The best part is that you thoroughly covered all of the methods and how each one applies to each scenario.
Carl
Yeah, I second that...GREAT POST!
Very informative videos as well.
Being a machinist helps. And knowing how to hand grind a drill also helps. I have bought special spot weld drills, and cutters in the past. The best thing I found was to hand grind a cobalt drill I forget the diameter, just measure the diameter of the spot weld for that, anyway I grind it to a very flat angle. I'm thinking something like a 170 degree included angle.
If that, even when using the store bought spot weld drills I still always center punch and use a center drill to make a start spot, then your drill isn't dancing all over the place.
Its not a perfect deal so using an air chisel and hammer and chisel is sometimes necessary to help separate the panels..
