4 members (2-Ton, Ponchogl, Robert Crandall, 1 invisible), 89 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#1310190 05/09/2019 10:15 PM
On my '54 6100, my brakes were working fine on Tuesday. Wednesday morning I get in it and the pedal goes to the floor. I checked the master cylinder and there is just a little bit of fluid in it. I don't have any leaks (the truck sits on clean concrete so it would be easy to spot). I had White Post rebuild the hydrovac booster but my concern is since I don't seem to have a leak on any lines, master cylinder or wheel cylinders, I can only assume that I have blow back from the hydrovac going to the motor and is being burned up. Has anyone else had this issue and what would be my next step. I got the hydrovac booster back from White Post in January.
kclark2227 #1310191 05/09/2019 10:34 PM
My experience with fluid getting into a Hydrovac vacuum chamber is that it will produce huge clouds of choking white smoke once it gets to the engine. That big vacuum drum can store a lot of fluid before that happens, however.
kclark2227 #1310209 05/10/2019 12:42 AM
7
7 Offline
If your positive that the wheel cylinders aren't leaking then it's the hydrovac.
