1 members (baldeagle),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | On my '54 6100, my brakes were working fine on Tuesday. Wednesday morning I get in it and the pedal goes to the floor. I checked the master cylinder and there is just a little bit of fluid in it. I don't have any leaks (the truck sits on clean concrete so it would be easy to spot). I had White Post rebuild the hydrovac booster but my concern is since I don't seem to have a leak on any lines, master cylinder or wheel cylinders, I can only assume that I have blow back from the hydrovac going to the motor and is being burned up. Has anyone else had this issue and what would be my next step. I got the hydrovac booster back from White Post in January. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | My experience with fluid getting into a Hydrovac vacuum chamber is that it will produce huge clouds of choking white smoke once it gets to the engine. That big vacuum drum can store a lot of fluid before that happens, however. Jerry
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | If your positive that the wheel cylinders aren't leaking then it's the hydrovac.
