| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | The wood spacers that support the bed on my 47 half ton are gone and I'm planning to replace the bed wood soon. I really hate the idea of ordering 4 wood blocks with a hole thru them. Any one have know how thick (tall) they need to be? | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Not sure if a 47 would be the same, but on my 51 3100, I cut them 2" x 2" x 2-1/8" tall out of scrap pieces of treated 4" x 4" posts. Drilled a 1/2" hole through the center, put a couple coats of back paint on them, and used a piece of gin belt (which was about 3/16" thick) as the rubber spacer. Everything lined up and the bed sits correct.
Mike
1951 3100 5 window
| | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | That sounds like exactly what I was thinking. I'm betting mine is the same thickness.
Thanks! | | | | | Joined: Nov 2018 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2018 Posts: 122 | Mark,
The wood spacers for my 51-3100 are 2 1/8" tall, plus the 1/4"rubber isolator pads between the frame rail and the wooden blocks. I got the bed mount kit from LMC Truck, it included the blocks, isolator pads and hardware. Hope this helps.
Charlie
'51 3100 5-Window (Restomod in progress)
| | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | | | |
