7 members (Gdads51, TUTS 59, mk72, ShopRag, Stovebolt48, Hush, Otto Skorzeny),
117
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | I have many new voltage regulators that came with a collection of parts. Basic, standard looking black, rectangle, delco style regulators. They all have different numbers on the backs. On the inside the all look the same. How do I tell if for 6 or 12 volts? And perhaps what trucks they go with.
Numbers include. 8AA 3KD 1HD 9CB 2LB 7FA
Thanks.
Trombones Totem Poles And Old Trucks!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not know how to determine 6v vs 12v I think you have date codes, not part numbers?
Year Month Day (Maybe?) I do not know how to determine decade.
8 A A could be:
8 = 38 48 58 A = January A = 1st (Happy New Year?)
Maybe someone know better/correct interpretation? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The 6 volt Delco regulators that I have seen all have two screws in the covers , one in one corner and one in the opposite corner on the diagonal. The 12 volt regulators have a flange on each end at the base level. t The cover screws are short, one on each end at the flange. This does not apply to aftermarket regulators. | | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | Check the cutout relay closing voltage- - - -this can be done with a simple battery and a rheostat. The regulator doesn't even have to be mounted on a vehicle. PM or email me for a more detailed description. Jerry
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Used to always switch to a solid state regulator on both 6v and 12v. No coils/contacts to mess with. They (used?) to make solid state kits to fit into the original housing for the purists. Think most solid state ones run about $20 on ebay. Before internal regulator alternators we used the 64-69 Chrysler one wire in--one wire out regulator on the street rods. Very small and dependable so a mounting place was easy to find.
Evan
