8 members (dt235sd, Lonnie, Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 2 invisible), 193 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#1309482 05/04/2019 11:40 AM
Robert here with my 49 half ton, 235ci engine. I’m noticing lately a lot of gray smoke coming from blow by tube. Engine operates at normal temp 170 when hot and not overheating. Anti freeze at normal levels. Any thoughts? Much appreciated.
Compression check. 170 seems cool for a normal operating temp.
Temperature would be dependent on the thermostat value........160* thermostat and 170* running temp would be normal. Also going to vary on where temp value is measured. Some use 180* thermostat to run warmer.
As for the smoke or vapor..........condensation vapor would be normal. When was the oil changed and how is the truck be used ?
On hard acceleration or decel does it smoke from the tail pipe.
What is the history of the engine? Rebuilt ? Compression or cylinder leak down testing would measure the general health.
Blow by on well used engine would be expected.
Large amount of water vapor from the draft tube on truck that is used casually could also be normal. It takes a long time for the oil to reach temperature.
Operating with a low coolant temp will adversely affect oil temp.
Robert, as others have indicated you may not have a serious issue at all. A quick question and suggestion. How long does the truck set between drives? And if weeks at a time or it's generally only used to go short distances (3 or 4 miles) a monthly drive of 20 or so miles continuous driving will get everything up to temp, cooking off any moisture in the engine and oil as well as the differential and transmission. Worse thing we can do with our classic vehicles is not drive em.
Added as an afterthought. Change the oil to 15w40 diesel rated oil. It's good for the engine and may help.
Good Luck
RonR
RonR
1970 340 Duster
1964 CJ5
Excellent advice by RonR
I never drive my truck less than 15 minutes at 45+ mph.
That should be enough to "vaporize" moisture, and to let the road draft tube do its job.
Thanks for the info fellow members. I really drive the truck occasionally and not in the winter months. I haven’t touch the motor as far rebuild etc. I put the truck on my lift today and inside the blow by tube walls I was able to remove a light coating of light brown gunk. One other time the blow by spit out this substance. I’ve changed the oil about a year ago and aa I said only driven it a little, and short trips were 5-10 minutes at speeds of 35-40 mph.
In answer to some of your questions, I have a 160 thermostat in there. On hard acceleration I don’t notice any unusual smoke coming out of tailpipe. I think a compression check would be wise as well as cylinder leak down testing. I’d like to do this myself and not bring to a garage. Do you need expensive equipment? I’ll change the oil a s you suggested Ron.. Thanks.
You can pickup a compression test kit reasonable at you local parts house. Pretty straight forward test. IMHO I would install a 180 stat, first and foremost.
If you have an O’Reillys or Autozone you can get a loaner compression tester. Disconnect the coil center wire. Block throttle wide open. Take all the plugs out. Get pencil/paper ready and start with #1 doing a dry test first. Record results. Then put a teaspoon of oil in each cylinder starting with #1 again for a wet compression test. Record the results. Report back with the results. 🛠
Change the oil and monitor the situation. Especially if it’s running good and not smoking from the tail pipe.
If the compression is low you would be looking at $2500-$5000 bill at the local shop.
Prior compression instruction given..........add If you do the compression test do on fully warmed up engine.
5 Online: Content
If your only "issue" is blow by coming out if the blow by tube, just drive it more often for longer periods. They are supposed to drip.
We don't rebuild our carburetors for carbureting, nor our generators for generating. (We do however change out our pistons for [censored], ) smile
Carl
I read a "funny" remark on another board about oil viscosity numbers.
"The first number is the time in seconds it takes for oil pressure to reach the last rod bearing. 5W: 5 seconds."
Not science but the trend is there.
Jus one question. Take all the plugs out or the plug wires off? If taking them out, where would I attach the end fitting?
To run a compression test you screw the fitting into the spark plug hole. Time for you to watch a YouTube video or two on how to do it.
If you're in a position where you can see smoke coming from the road draft tube, the main problem is that you're NOT in the driver's seat. Drive that thing like you stole it- - - - - -engines that get lots of exercise keep all the contaminants boiled out of the crankcase and they don't have issues with moisture buildup and steam. That's not "smoke" you're seeing- - - - -it's water. The road draft tube only ventilates the engine properly at speeds of 30 MPH or above.
Perfect opportunity to install the PCV upgrade........plus the 180* t stat.
http://devestechnet.com/Home/PCVInstall
Well said Jerry
