0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,441
Members48,443
#1283366 10/12/2018 1:55 PM
On my 49 3 window I used Boiled linseed oil on the Bed wood from Classic Parts. It stained when left out in the Rain. I just got Mar-K bedwood and plan to use Watco Exterior Wood Finish. Is this a mistake? Both trucks are garaged. Thanks Bill
If I remember correctly Mar-K has a comparison of different finishes somewhere on their website. Might be worth looking at.🛠
Yes, do as Martin suggestd.
Their best results were from a two/three coats of POR, followed by quality exterior semi-gloss house paint.
Follow carefully the recoat instructions from POR.
I had excellent results on 18' flatbed wood.
JD1 Offline
I make wood decoys and I seal them with soar varnish before paint. Does anyone every use that on wood bed?
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
Never heard of "Soar Varnish"? Are you talking about "Spar" Varnish?
