1 members (klhansen),
136
10
Mod | | | Forums66 Topics128,281 Posts1,058,470 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I noticed fluid on the back rim of my 58 3/4 step van. From different posts I read, I guessed rear wheel seal was bad. Brakes and hardware were layered in black gunk. The seal looked ok, but what do I know-I then read about other things that might cause leaks. Too much fluid, some axle vent? At this point I will likely replace the seal anyway. I also remember this leak coincided with my differential swap. Coincidence? Anyway, could someone please school me on what might going on.
1958 Chevy Grumman Olson step van
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Chaz 58 If you pulled the axle all the way out of the rear end housing, you may have dragged the axle splines on the rubber seal. Damaging the seal, thus the leak. Just a thought.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Possibly. I couldn't detect any damage to it though.
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | A worn axle bearing that allows the axle to bounce up and down on the seal, or a worn surface on the axle shaft where the bearing rides is the most common cause of a leaky seal. Try to move the axle shaft up and down with the brake drum removed. Anything other than a very tiny up/down movement is too much. If you can see the axle move up and down, replace the bearing and/or the axle as well as the seal. There's no way to get all the oil out of the brake linings, also. Jerry
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I had no movement when moving the axle shaft. I read about the brake pads needing replaced. They were looking a little thin anyway. Is there a "best" way to knock out the seal. I'm a little worried about getting everything back together right. I took pics, so...
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | I use a big pry bar and just manhandle the seal out of there. Be sure to inspect the axle shaft just inboard of the flange for pitting, scoring, or other damage. Sometimes there's a wear ring where the axle has been running in the bearing, noticeably smaller diameter than the rest of the shaft. If so, the axle is junk.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Lincoln did you ever hear about anything about high fluid level or vent being clogged causing seal failure? I briefly looked for a vent on my axle but did not see any trace of it.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | He said this is a 3/4 ton. It will have full floating brgs. The vent is a little noggin somewhere on top of the housing. It has a little cap on top of a tube. If you can wiggle the cap, generally the vent is clear. Too much rear end grease can cause it to leak. It should be level with the plug on the rear cover. You more then likely have a bad seal. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | I wouldn't replace the shoes without doing the seals. The hub bearings need to be adjusted correctly in order for the seal to work. | | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | How old are the seals? Seals don't last forever, sounds like a bit of over-thinking going on. Even new parts can fail, or maybe they were installed incorrectly if they were recently changed.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
| | | | | Joined: Sep 2011 Posts: 1,468 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,468 | He said this is a 3/4 ton. It will have full floating brgs. George Glad you caught this, I was about to chime in!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 |
Glad you caught this, I was about to chime in! [/quote]
Yes, the axle doesn't ride on the brg. The seal doesn't ride on the axle shaft. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2018 Posts: 84 Awesome Grandpa | | Awesome Grandpa Joined: Nov 2018 Posts: 84 | I use the end of the axle shaft to pry out the bearing. | | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | OOPS! I missed that "3/4 ton" part! If those seals are leaking, you've either got a bearing problem or improper preload on the adjusting nuts that retain the hubs. The seals are very sensitive to nicks and tears while the hubs are being installed. Jerry
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Are you sure it's not brake fluid from leaky cylinders?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | No, it's definitely the differential fluid. I ordered a seal, so now I wait.
| | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | Do you have a shop manual? If not, you can find useful info here in the 55 Truck Shop Manual. Good luck.
Professional Novice
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | The new seal is on. I'm putting on the retaining nuts. How tight should they be? The hub spins about half way around with one spin right now. Thanks for the manual sir.
| | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | You're welcome. Glad it worked out.
Professional Novice
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | I usually tighten the inner nut firmly, enough to require a little effort to turn the hub, then back off slightly until one of the lock ring tabs can be bent down to secure the nut. Then tighten the outer nut securely with a socket or a flat-tipped punch and bend a lock tab outward to retain its position. Jerry
