2 members (Donf, 50Chevy3100),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,076 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2018 Posts: 84 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 84 | Hello All
I have a 1953 Chevy and I am putting together a tools kit to keep in the car. Does anyone have a list of the useful spanner sizes for road side repairs rather the major overhauls. I don’t want to carry everything including the kitchen sink but it tends to be what I end up with anyway.
Also going to Cary
Rotary Arm Pertronic Igniter Coil Distributor cap 1 long ht lead Fuel filter Fuel pipe Jubilee clips 1 rubber brake pipe. Some wire Fuses. Some crimps Assorted nuts and bolts Fan belt Lamps
Any other idea. Been out twice in the new truck. Broke down twice!
Regards Chris
| | | | | Joined: Jul 2000 Posts: 2,195 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,195 | Had to look it up: https://en.wikipedia.org/wiki/Jubilee_ClipPerhaps all you need is a credit card with roadside assistance / towing. Carry a cell phone (mobile) to call for help.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | For any older Chevy, 9/16", 9/16", and 9/16"  Seriously, a set of combination wrenches (box and open end) from 1/2" up to 3/4" would fit just about anything. I sewed up a rollup pouch from some denim (old jeans) with velcro closures. Pretty compact setup. Or you could go with a couple of adjustable end wrenches (aka Crescent wrenches).
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2018 Posts: 84 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 84 | Gord
lol what do you call jubilee clips ?
Two great nations separated by a common language
Well I called out the breakdown truck but walked home and back and fitted a new coil. I so hate breaking down.
Chris
| | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | They call them cresent in New Zealand a shifter as well and jubilee clips
| | | | | Joined: Jul 2018 Posts: 84 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 84 | I nearly always carry more tools than I need, but I would like to be a bit more selective. Just remember a role of Duct tape.
I have quite a lot of modern imperial tools, but I think I will make a point of looking for some old brand grandads tool box tools. I like collecting tool at automotive jumbles and car boot sales.
Chris
| | | | | Joined: Jul 2000 Posts: 2,195 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,195 | To me, a Jubilee clip is just a hose clamp.
Kevin suggests a Crescent wrench; adjustable spanner to you (or in London, an adjustable Judy Dench?) Recently, I bought a Knipex pliers-wrench. I think that it would be ideal for the truck tool box. It will replace Crescent wrench and pliers although it can't cut wire.
To your list, I would add rags, gloves, multi-bit screwdriver, spark plug wrench.
You mention wire - I would take a small roll of rebar tie wire. Great for temporary fixes.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | I nearly always carry more tools than I need, but I would like to be a bit more selective. Just remember a role of Duct tape.
Chris You can't be considered a real Alaskan if you don't have at least 2 rolls of duct tape.  I'm assuming an "automotive jumble" is a swap meet. What's the US equivalent of car boot sales? I know that the Brits call a trunk a "boot" and a hood a "bonnet" but not sure exactly what a car boot sale is. Interesting bit about Jubilee clips. Kind of like the Kleenex or Band-Aid thing over here - every tissue is a Kleenex and every self-adhesive bandage is a Band-Aid.  I have collected a number of vintage tools, even some Ford ones.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2018 Posts: 84 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 84 | Jubilee Clips are just hose clamps but are a particularly type that use the worm drive. Autojumble is a swap meet but I only ever swap good hard cash for old junk.
Rags, gloves and fence wire is a good idea. We have armoured cables here that are a good source of steel galvanise steel wire.
Not had much luck with adjustable spanner’s but I cannot argue the utility
Thanks Regards Chris
| | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Fit-all, binder twine, bailing wire, and Dikes. That's all you need, except maybe an American to UK translator.  Carl
| | | | | Joined: Sep 2013 Posts: 1,366 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,366 | [quote=klhansen]For any older Chevy, 9/16", 9/16", and 9/16"  Chris, good advise above, but from my old TR3, TR4, and E-Type days (all early 1960 vintage) I recall Whitworth sizes sometimes causing trouble. A 1/2" Whitworth equals an American 9/16th. So, as you put together a set of era appropriate tools, would Whitworth tools be British appropriate?
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
