5 members (WICruiser, GMCJammer51, Otto Skorzeny, Phak1, Greg_H), 114 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#130770 12/10/2002 4:35 AM
i am poking around for info to see if i can swap a later model th350 into my 61 chevy w. a 235. i am no longer able to use my left leg, and i do not want to sell my truck. i refuse to give up on this thing and powerglides are pretty scarce.
HELP
1961 Chev 3/4
1977 Chev Nova
#130771 12/10/2002 11:41 PM
if the powerglide will bolt up shouldnt the TH350, i think the bell housing pattern is the same.
#130772 12/11/2002 6:46 AM
The 62 and earlier powerglide has a major difference from the 63 and up powerglide.
#130773 12/13/2002 2:02 AM
Stovebolt Engine Co. make the adapter you need. www.stoveboltengineco.com/index1.htm
