| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 47 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 47 | Howdy all!! I have a 59 Burb. Working the front end. Anyone out there ever rebuild the stock anti away bar, bushings, etc. on one of these. If yes, I'd be curious to know what you used for replacement parts.
Thanks! Maddog | | | | | Joined: May 2015 Posts: 11,109 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,109 | Haven't worked on one that old, but Energy Suspension has bunches of bushings. I've used them on my newer truck. You'd probably need to get them dimensions to match them up on something that old. Energy Suspension Sway Bar Bushings
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check Taurus parts about 1989, some bits are the same
