| | | Forums66 Topics128,156 Posts1,057,017 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | I have completed installation of a 1984 T5, in my 1942 3/4 ton truck. It makes a helluva difference in drivability. However, I would still like to change the 4.56 ring & pinion out for a stock 1/2 ton 4.10 R&P ratio. Problem is I can't find any information anywhere (including part numbers) to tell me if the 1/2 ton 4.10 R&P will replace the OE 3/4 ton 4.56 R&P, without modifications. Since 1/2 ton was torque tube driveshaft, and the 3/4 ton is open driveshaft, I'm wondering if the R&P specs for diameter, length, seals, etc. is interchangeable between the 4.10 & the 4.56 R&P? Since it seems no one is making a 4.10 or 4.11 R&P for the 3/4 ton Art Deco trucks, I figured maybe an OE 1/2 ton set might work. Sure would appreciate any input from the experts, before I start spending any money. Thanks.
Ghost Rider Little Egg Harbor, NJ 1942 Chevy 3/4 ton pickup, 1962 235, Offy intake, Fenton headers, Dual Carter YFs, 1984 T5 1956 Chevy 3100 Apache, 67 350SBC, Saginaw 4 speed, 69 12 bolt
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I swapped out the 4:56 pumpkin in my 53 3/4 ton 3600 to 4:11s bolt in swap, now if this works back to 1942 I don't have a clue. Measure the bolt pattern on your 3/4 ton rear and compare to 50s-60s trucks. IF you are in luck re. size and bolt pattern then you need to locate a late 60s 3/4 ton that came stock with an automatic trans (make sure it's 4:11). If your truck has 6 lug hubs none of the above applies. This info is for 8 lug trucks.
BTW, I'm running a 6 lug truck rear end out of a 1966 Chev pickup in my 1946 half ton. Gears are 3:08 and lots more ratios can be found in these years.
Best of luck
| | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | No interchange between 1/2 ton & 3/4 ton
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Nov 2010 Posts: 114 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 114 | Thanks for your input. I was aware of the 55-62 pumpkin swap from the Tech Tip article listed in the Stovebolt files. I do have one of these carriers (3.90) from a 55 1/2 ton. Yes, it would bolt right in to my OE 42 housing. Unfortunately, so far, I haven't been able to find all of the bearings and gears needed to rebuild the 55 diff carrier that I have. I kinda figured that the 1/2 ton R&P would not fit my 3/4 ton diff, what with the OE difference between torque tube in the 1/2 ton, and open driveshaft in the 3/4 ton. I'm gonna keep looking for the parts to rebuild my 55 carrier. I don't want to give up my OE artillery wheels and 6 lug axle configuration, so swapping out the axle is not my first choice, unless someone can recommend a later model axle that will allow me to mount my OE 6 lug artillery wheels. Thanks again for your help.
