| | | Forums66 Topics128,088 Posts1,056,109 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 18 | Does anybody make a replacement gas tank for these trucks? Thanks for any info. | | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Hummm...I used a 53 Chevy car gas tank new plastic one and re mounted it to the rear..driver side of my 46 Chevy panel Comes out on rear fender ...fit in real nice
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Feb 2019 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 18 | | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Hello, I tried to send a PM, but not sure it worked. So thought I should try the forum. Did you get a gas tank for your Burb? Richard
Richard J Patrick - 1946 Suburban
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do not reply here - send a PM (or, check your PMs - Private Messages). | | |
