4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#1307117 04/14/2019 11:28 PM
Before I whack away on drum like I had
to on front drums, thought I'd check with
you guys first. Shouldn't this just come
off same as front ? That's what FSM says.
[img]https://flic.kr/p/24Vyhop[/img]
rear drum
1960 C20 Platform
Looks to be a captive drum, you will have to remove the axle, then the hub/drum assembly. Hub lock nut requires special socket to remove, if you're lucky it maybe the same as front hubs on 4 wheel drive's and can be bought or even borrowed from one the chain parts stores.
ESum
That one needs to come off hub and all as one assembly, hub, drum, bearings and all. Now please tell me that there's a jack stand involved somewhere in this project, and you're not supporting that big truck with nothing but that Mickey Mouse toy jack!
There is no weight on the 'disney' jack.
It does the lifting job (only). I'm a glutton for
punishment. Plan to get a nice floor jack
someday.
So. I see in the manual about removing all that
like a big mess - is this still a  ¾ ton rear ?
I don't experience in 'larger' trucks, but this
looks to me like one could put duellies there.
1960 C20 Platform
I believe the same axle and hub was used (with a bigger brake drum) for 1 ton dual wheel setups. I had a 1959 3800 flat bed truck with the same basic rear axle and 14" brake drums.
I suppose I'll wait until all apart to see
shoe size, but I was able to pickup front
2.8" x 11" shoes - at Autozone.
I know back shoes in sad shape, since
front were hardly worn.
1960 C20 Platform
Typically front shoes or pads wear more than rears, unless something is really messed up.
I guess it is on the red 60 or 61 truck in the other pictures? The rear cover looks like a Eaton HO52/72 axle. I agree with Lincoln that it looks like a dually hub. You sure the truck is not a C30 (1-ton)? I think Chevy still had the HD 3/4-ton option with rear duals at that time. Good luck.
Professional Novice
ESum #1307480 04/18/2019 12:29 AM
" Hub lock nut requires special socket to remove "
If I read manual correctly, the tool is J-2222.
When I google it, I see a few different styles
for the same #. Anyone have a good picture
and/or location to buy one ?
I plan to work on this a long time, so I might
as well buy the thing.
edit: oh, VIN says it is definitely ¾ ton Platform
built in K C .
edit : never mind, bought tool at oreilly - $10.99
Hub off in 5 min. y e a !
1960 C20 Platform
(continuing my own thread...)
So, all cleaned - new shoes.
Greased bearings. (I know, oil will eventually coat them again)
B u t , there is only about 1" of room to insert tool
to adjust star wheel to expand shoes to useful point.
I am probably going to heat/bend an old screwdriver ;
is this the usual plan ?
Or is there a perfect little tool for this I haven't found ?
( also picked up a harborfreight floor jack on sale -
apparently made in same factory as Snap-On )
1960 C20 Platform
dbwr #1312843 06/01/2019 11:50 PM
There are lots of brake adjusting tools on the market. I have several, from a Mac to a Harbor Freight to a couple homemade/ bent to work on an oddball. An important tip: film of grease on the contact points on the backing plates where the shoes rest, and also take your adjusters apart, clean and lube the pin/ swivels and make sure the spring washers are in place. You want that thing to turn really free for adjusting up. Also if you can reach in the corner with a small screwdriver/ punch etc. and hold the adjuster bar in off the star wheel to adjust up it makes it easier.
Thanks ... I ended up adjusting with wheel / brake drum off,
mount drum - spin, remove/adjust/mount spin, etc.
About to do the wheel cylinders since I could not - for the
life of me - get them bled right. ( not first bleeding rodeo ).
1960 C20 Platform
