3 members (Uncles51, 78buckshot, Bill Hanlon), 96 guests, and 0 robots.
Topics128,043
Posts1,055,614
#130707 05/04/2005 10:28 PM
I have a Holly Avenger carburator on a modified 383 chevy engine with a 700R tranny. This on my Nova, not my truck, but was hopeing someone will help anyway. The problem is when I get on it going about 30 or 40 miles per hour the engine will bog down and backfire through the carb. If I get on it gradually there is no problem and there is no problem from a dead stop. The carb is almost brand new, but I did screw around with the fuel levels and the idle adjustment. This is for a 4 barrel. Any ideas? Cecil..........
#130708 05/04/2005 11:33 PM
Riding in the Passing Lane
Set the float level so fuel is at the bottom of the holes on the side of the bowls. Turn the idle screws in till the engine starts to slow down & turn them out about 1/2 turn. Check the timing. Try running a few degrees advanced from specs.If that doesn,t do it you may have to increase jet size or accelerator pump. smile
1972 Chevy c10 Cheyenne Super
#130709 05/05/2005 4:52 AM
Thanks Wrenchbender, I'll give it a try. Cecil.....
#130710 05/23/2005 6:47 PM
try replacing the power valve.its a holley.can't ask for anything move or less
dan-pa
#130711 05/30/2005 11:24 PM
Junior Member
Junior Member
Usually backfire thru the carb is too much timing. While all of the above responses may also be true, it would seem that you have too much timing at partial load based on the description.
"...there can be only one..."
