| | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13071 10/11/2004 11:31 PM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | I posted this in the 'Big Bolts' section, but wonder if you guys could help with the engine ID.
hi folks, this weekend i got my hands on a big GMC. unfortunatly i dont know anything about it. there is an oval badge on each side of the hood that says '3 TON'. I know it was made in Canada there are two badges attached to the door pillar that say:
Model 9773 serial 0977312337 Engine G28643 Body Serial 577 Trim 394 Paint FC94 the max weight rating is 16000 lbs
I dont even know what year it is, but its the same body style as my '48 (AD) The gas tank is behind the seat inside the cab, and the front glass is two pieces.
I pulled the engine out and was even more confused to find that the only casting number behind the starter motor was '5'
there is no casting # on the plate behind the distributer, it is blank, and appers to never have had a number their (does not look like it was tampered with)
i did find a number cast into the block below the exhaust manifold that reads '6107328' does anyone know what this engine is? or for that matter anything about the truck?
1948 3600 thriftmaster
#13072 10/12/2004 12:55 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I answered your post in Big Bolts. However, I forgot to mention some of the clues to the year. Does your truck have the "no vent widows on the doors and does it have drop door handles or push buttons ? | | |
#13073 10/12/2004 2:22 AM | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | The side windows have no vent windows, and the handles are drop down, no push buttons. I think it's a '50 after doing a bit more research, Could this be correct?
