2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1306498 04/09/2019 11:40 AM
0
0 Offline
Does anyone know of a source to obtain 1/2x20 flat faced lug nuts?.....Thanks
Harold
Fastenal. Silicon Bronze finish #0178882: heavy hex #0158659.
0
0 Offline
Didn't think to try Auto Zone....actually a few months back I went in there looking for a 'choke pull off' - they had no clue what I was talking about, and never heard of such a thing....I think looking for these lug nuts would fall in the same category........Now Fastenal....sounds like a sure bet....will check it out....Thanks !!!
My COE had hub-centered wheel attachment - the wheels centered on the axle hubs.
The bolts had flat backs, no flange, and small slits in the top, like "Castellated" and "Marsden" nuts.
I do not remember if they had cotter pins (I think not).
Mine were relatively rare large Marsden nuts (image is attached, below). I found the part number, searched the Internet, and found 50 at $1 each (I needed 40).
Fastenal was going to be my next search.
Try these previous threads
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1213797/Searchpage/1/Main/177795/Words/%2BLug+%2Bnut+%2BMcMaster+%2B/Search/true/re-lug-nut-size.html#Post1213797
•1952 Chevrolet 3800 pickup
---All pictures---
0
0 Offline
Bartamos....My truck is a 1970 C30 mason dump....See my post titled '70 C30 wheel conversion' Fastenal was the solution that had a 1/2x20 nut with a flange 10 per bag @ $7.59....Isn't that sweet.... My luck on line, as with e-bay didn't turn anything up.... If you view my post on the wheel conversion Grigg was helping me, much appreciated.... but at the end of the day, I ended up using the original type wheel.....I wanted to avoid the rim with the outer ring & tube, but to no avail....I used two of my original wheels & located 2 more....Right now they are out being sandblasted & powder coated (after I straightened with the torch the sledge hammer blows on the edges) ....all set up by a truck tire shop where I will purchase the tires...I opted for radials 215/85/16, rather than the bias 750/16 which I would have preferred but they had no source other than Coker. Seeing they were so good about breaking down 7 wheels to find two good ones I felt obligated to by the tires they had in stock...Goodyear/Firestone.....Can't bring myself to buy & look at the Chinese brand.....despite the savings.....I'm still amazed on how stupid people can be....The guy I got the truck from had the original rear inner wheel with the late model wheels on the outer, neither hub or lug centric just a couple of large flat washers with standard coned lug nuts installed backwards....
I actually read through this forum a while back and said to myself, "ha, I never seen them b4." Low and behold I bought a gmc 2500 chassis a few days ago now and just noticed last nite it has the same lugnuts. Go figure. lol. Do you happen to know what torque they are supposed to be at?
H Online: Content
I've been known to use 1/2-20 tapered lug nuts on a 1959 3800 I had- - - -turned backwards. They look a little strange, but they hold the wheels on just fine!
I just took the wheels off my roller and put it on jack stands. Same lug nuts. They weren't tight at all. My wifes car lugnuts were tighter yesterday when i had a tire to repair. Anyone know what the actual torque spec is supposed to be for these? My roller is a 63 GMC 2500.
I forget but it is in the shop manual...
---All pictures---
H Online: Content
Standard torque for a 1/2-20 bolt is 90 ft/lbs. with the threads lubricated, or 120 ft/lbs. dry. I've always used 100 ft/lbs. as a rule of thumb for 1/2" lug nuts and I've never lost a wheel due to the lugs backing off.
I’m thinking the manual says about 50-60 ft lb. Someone should look in one and see... I don’t have one with me.
I do have my torque wrench with me and it is set to 55 from last use, pretty sure that was flat lug nuts on my 1 ton GMC.
---All pictures---
I dont have a manual either. Wow 55 ft lbs is not tight at all. Seems light?? AS a rule of thumb, Ive have learned years ago after use of a torque wrench, turn it down to (0) when done or at least the lowest setting it has. Ive heard that leaving them set up somehow screws with the calibration. I have no proof of this. Its just what I heard about some 25 years ago.
Book says 65-90 ft lb.
I must have used the wrench for something else in the meantime.
Some torque wrenches don’t need adjusting to zero, snap-on TQR series for example, no spring is left compressed as in twist handle types.
---All pictures---
Thanks for the spec. seems like a big variance. Ill be at 90 for sure. Good to know on torque wrench also. I think all of mine are twist handle type. So I guess that's why they should be zeroed.
Moderated by  Dusty53
