Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (2-Ton, Peggy M, Youngin' Tut 59, Jon G), 36 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#1306783 04/12/2019 2:16 AM
I'm running a 235' with a 848 head and a Mellings hydraulic cam. I'm not sure what head the 261 guys are running, with still a little knock in the upper valve train area I have backed off some of the rockers to notice some pretty deep prints on the rocker arm from the valve stem. I did not know if taking these rockers off and polishing back to a clean surface would be suffecient? This engine really runs good, but that slight little knock say at 1700 rpm's is not what I like to here.I have set the lifters the way Hot rod Lincoln explained to me. A friend of mine said to check the rocker shaft versis the rocker arms for clearance. You know by looking at some of the rocker arm numbers don't even match the shop manual numbers? The manual also mentions R/H exhaust/intake and L/H exhaust/intake now what determines this? Thanks there Bolters....
ol' 55 #1306789 04/12/2019 3:08 AM
Refacing the rocker tips is a common practice.
High speed lifter noise is usually caused by air trapped in the lifters.
You may want to read this .
You can determine rocker angle by laying them on there side on a flat surface.
Here is a pic of there correct positions.
My Blog
ol' 55 #1306821 04/12/2019 1:54 PM
Now is there a spec. for the o.d. of the rocker shaft vs. the i.d. of the rocker arm itself? What would be the best way to polish up those rocker tips? Thank you
ol' 55 #1306955 04/13/2019 4:19 PM
I use a 6" disc sander with a piece of 320 or 400 grit stick-on paper for polishing jobs like that. Hold the rocker square to the disc and freehand the radius of the tip against the sandpaper until it's smooth. Some valve grinders also have a rocker-facing accessory.
