10 members (dwreills, Gdads51, 32Fordpuchoptop, chevy51truck, Phak1, klhansen, 52Carl, KEVINSKI, Woodcmiami, 1 invisible),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | I am doing some rear axle work , I found a 4:10 third member and plan on swapping out the 4:56, I’m also planning on doing the brakes and axle seals at the same time. I just need the torque for preloading the axle bearings when reinstalling the drums. Thanks
1962 GMC 920 step side 261 4 spd
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is in the shop manual. The procedure is very specific. | | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | Thanks for the reply I actually did think of that but since I don’t have a shop manual l was thinking someone with a manual might relay the info. I did buy a 62 shop manual but it was for the American built GMC truck and did not cover the axle I have in my truck.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is the procedure for the 1954 truck. I think yours will be the same. GM Manual
