6 members (Donf, mo2cyl, Barney1951, Steelonsteel, Stovebolt48, TUTS 59), 78 guests, and 2 robots.
Topics128,031
Posts1,055,435
Members48,422
#1306359 04/08/2019 1:58 AM
My panel truck body came finish-painted in black epoxy primer (DP90 I suppose). I need to do some body work; what's the best way to blend in new paint over the repair? Is there a technique that will work with epoxy primer?
1951 Chevy Panel Truck
Sand with 180 grit without burning through it anywhere you will be applying body filler.
Move up to 320 grit before final coat of epoxy primer (if you are staying with epoxy primer as the final finish).
Epoxy primer acts like filler primer when you sand it, except that it is harder. It feathers nicely in my experience.
