0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | Looking for any recent info on coating(s) for a wood bed. My ‘47 AD 1/2 ton is awaiting an oak bed from Mar-k. I don’t want to paint the bedwood. I’ve read the articles here, elsewhere on the net and on the Mar-k web site. I’ve done a lot of wood working so I’m familiar with spar varnish etc. The truck will sit outside but see winter storage. Realizing there are many proven approaches, they all ultimately fail. Many posts of the proven techniques date back a few years also. So I’m torn between old proven practices and something that be more modern and more durable. I’m leaning toward an auto clear coat type finish over a light stain/clear wood. With the MANY approaches, I'm wondering if there are updated experiences/tests that are using multiple auto clear coats on all 6 sides? I wonder if Mar-k has experimented with this covering? “Any pearls of wisdom” you can share would certainly help me and others! Thanks. | | | | | Joined: Sep 2018 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2018 Posts: 37 | Ok after owning and operating a paint business for 40 yrs. just a couple cents of thought! Sun and weather is the enemy of wood, steel ect. One job was spray painting a banked barn with linseed oil and red "oil" base enamel! With many barns under my belt latex paint faded quickly, just oil base took longer to fade but the linseed oil base paint lasted the longest very slow drying time tho. Now my 59 truck bed oak wood I stained then applied 4 coats of Marine varnish to the top the secret for me was to be patient for the varnish to completely dry before sanding between coats. Everybody that sees the bed just goes nuts many, many remarks how beautiful it is. It will be stored inside specially winter time. Now my 20 ft. trailer I use to haul my tractor on an old farm boy trick that was taught to me I use hydraulic oil mixed with paint thinner, brush and roll it on!. The trailer sits outside 24-7 and am very pleased how it has maintained itself. Yes, I am retired so I will do this process more often!
Pops
Pops the truth is out there!
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Pops, Say that again and with pictures. Hyd oil and thinner? I am thinking my K10 will have rough sawn oak planks and I was thinking of an oil or semitransparent stain. I dont want a finished look. How does the hyd oil set up and what color does it turn?
| | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | 47Jim, you probably read our tests from 2005. At that time we did test two samples with epoxy seal coat and automotive clear topcoat. They held up fairly well but showed failure starting a little less than a year outdoors 24/7. A down side of automotive clear is that it goes on water clear and does not change the color of the wood at all. As noted, many prefer the warmer slightly amber color of furniture natural finishes. Of course a truck that does not sit outdoors all the time will likely have a much longer life before wood finish failure. The oak bed wood finished with Helmsman that was in our showroom for 25 years still looked great. It was never outdoors.
We will be presenting additional test results on finishes soon. Stay tuned
Mar-Ktech | | | | | Joined: Sep 2018 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2018 Posts: 37 | Hambone: Actually I would go take a picture but it is covered with snow now. Not worried about the bed at all. It does turn it a little bit darker try a test piece for yourself. The hyd oil with thinner makes it soak deeper into the wood for me it doesn't sit on top so the thinning of oil soaks better! I was worried at first that it would be slick but it was not. Greatest thing water does not soak into it. Sun will dry it a little but that is why I plan on doing it about every 3 years. I live in a farming community all the guys do it and after haveing to replace a trailer that had painted floor and it rotted out the new trailer will be taken care of right! If you want it darker put a little bit dark oil penetrating stain with it. Appreciate you using rough sawn oak that is class. Now take care of it! Mixture I used was a qt.of thinner to a gallon of oil!
Pops
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Thanks Pops. I will get it a test. | | | | | Joined: Mar 2019 Posts: 6 New Guy | | New Guy Joined: Mar 2019 Posts: 6 | Now that's an interesting approach. I just got a 66 c10 for my 16 daughter and we'll be replacing the bed wood in it. I'll run the hyd oil (and thinner) idea by her. Seems simple and more effective. Appreciate the info Pops. | | | | | Joined: Sep 2018 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2018 Posts: 37 | Your welcome Shane good luck with your build and happy trucking for your daughter! Building the 59 my last hurrah for my 45 yr. old Son and grandson! Great memories for all of us!
Pops
| | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Pops, hope you don't mind another question or two about your hyd. oil wood treatment. How long does this mixture take to dry or at least before it can be handled? Do you reccomend just one coat? If the truck is parked inside and only sees occasional rain, how often would you expect it to need a re-coat. I am really a urethane guy but just re-did the oak sides on my '46 and it was a ton of work. I would not look forward to having to take apart a my one ton pickup bed and re-doing it..... | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I have a test piece working. 2 coats so far. Looks nice. 2nd coat stayed oily (a little bit on finger fips) after a few days. I have it in the sun since. I plan to put another coat on. I will bring the piece to homecoming. | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Bill, After talking to a few people, I used linseed oil. I was told to apply it as needed when boards looked dry. I think it looks good! | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Thanks Chris. Definitely an option. HB, did you add stain to it? Considering I'm not allowed to restore this truck, both of these are options for the bed!  | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Bill, I was told to apply the oil whenever its dry, aboutveveryv2 years | | |
