0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
I'm in the process of building parts to bolt a late model vortec 4200 DOHC inline 6 into my '51 GMC replacing a just broken in 292 that for sale.
The vortec makes 275hp in full emmision trim from the factory! So in hot rod trim its closer to 300HP.
The work packages to do the installation are:
- Custom ford EDIS wasted spark crank trigger brackets and timing wheel designed to bolt onto the vortec with no mods.
- Modified oil pan and pick up
- change the throttle body from drive by wire to cable
- exhaust system
- engine wiring harness for the megasquirt EFI system.
- custom engine mounts
IF anyone else is doing a swap and wants to get rid of the GM electronics I can add extra EDIS parts to my machine shop order.
Oh my! My hat's off to you. I briefly considered this swap and decided it was electronically too complex for me.
Aren't there also issues with how the front suspension bolted to the engine?
The only components that bolt to the engine is the front axle center section on the 4x4 versions. Shouldn't be an issue using the engine with the 2wd oil pan.
You're gonna have to post some pix of the conversion, I know I'd like to see it installed.
GM had talked about producing a crate version of this engine, similar to their Ramjet efi engines. They were supposed to have a self contained computer, only needing power and fuel to run. Never have heard the reason why it was never produced. ohwell
Bill Burmeister
Junior Member
Junior Member
How hard is it to find a bellhousing for this engine that will bolt to a T5 or 700R4? I know they make them but all of the 4.2's I have seen are mounted east-west and not north-south.
East-west north south? Do you mean front drive opposed to rear drive? The 4200 currently is only used in the Trailblazer and it's assorted clones. It's strictly a rear/4 wheel drive engine, longitudinally installed, no transverse. I don't know about the bellhousing pattern, but all the current versions are using the 4L60E trans, so I'd think it would be the same as the current smallblock.
Bill Burmeister
Junior Member
Junior Member
I went to the dealer to look at one of these engines and the only thing they had was a Arcadia,New GMC Transverse mounted 4.2. All of the Older models had the 5.3 upgrade. If the standard trans used behind this engine is 4L60E then a 700R4 or any trans that will hook up to a sbc will hookup. All I need to find is flywheel and I will be able to use a T5.
The 5.3 V8 was an upgrade from the 4.8, not to be confuse with the 4.2 IIRC. The Vortec 4200 (er, 4.2) is an all aluminum 24 valve I6 that has been available in the Trailblazer for a few years now. Part of the story with the good power number is in the variable timing exhaust cam. Lots of great info on inliners. http://www.inliners.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=3;t=000538
The bellhousing bolt pattern is unique to the engine family which includes an I4 and I5 engine.
It is an impressive six.
mv
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
All '02 Trailblazers had the longitudinal 4.2...ALL. In '03 they offered the 5.3 in the EXT or extended Trailblazer. They sold so many that they're a dime a dozen now. I had an '02. Ran good but the power band was in the higher rpm's. Without emissions, it should scream and get decent mileage. Let us know how it works out.
EFI-DIY,
I'm curious why to went to the darkside for an engine management system. GM has some fully hacked 89-92 ECMs that give you reliabilty, DIS ignition, room for turbocharging if the future warrants it, etc.
MV
Darkside ....???
Hmm well for 1 I didn't have a factory harness or ecm. 2) I don't have the s/w to tune a GM ecm. 3) I've been using meagasquirt for 4 years now and know how to tune it. If it breaks I can fix it since the complete design is open on the web including s/w.
Last edited by KCMongo; 08/08/2008 4:21 PM. Reason: Switching Image to Link - http://www.stovebolt.com/news/2007/december2007/index.html#forum
In for update! What a bump back. Just started looking at the 4200's and wondering how much work it would be.
was there actually a 2wd version? If so can you swap a 2wd pan on and that's that?
'49 3/4 Ton
"It's hard to make a comeback when you haven't been anywhere"
Well, the OP hasn’t posted in 4 years but he is still checking in on us. Maybe he can give us an update.
The 4200 only has a front sump pan. Doesn’t matter if it’s 2 or 4wd. Mark, AKA, EFI-DIY has fabricated a rear sump pan and has them for sale. He is also working on getting flywheels machined. You can go to his website, emtechmotorsports.com for more info.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Thanks Whitedog! Found the website and reached out. Awesome that he has this stuff. He mentioned he has one in his '51, sounds like it's up and running as well.
I especially like the transmission conversion plate he has so we can run a more 'standard' transmission. I think the stock ones mated to the 4200 were a little iffy, seen quite a few Trailblazers, etc for sale with blown transmissions.
'49 3/4 Ton
I don't necessarily think the transmissions are the weak link. Most seem to go over 200K. When you compare that to the earlier 700R4's that may have went 50k, I'd say the 4L60E is pretty good. I want to say the 05 and later transmissions had some upgrades for more torque capability. One of the issues I have is actually finding a 2WD trans. Here in the midwest, I bet 90 percent of them are 4wd.
"The Fake Truck"
