1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#130618 04/08/2005 12:27 PM
Wasn't sure where to post this question but since my 38 is a hot rod thought I would post my question here. Had my truck out on the road for first real test yesterday. Everything was good except I noticed that when I was doing about 45 MPH my speedometer was reading almost 60, that's a big difference. I have Stewart Warner gauges and a 350 transmission, 15 inch tires in rear. I know there are different speedometer gears, but have never had to deal with this situation before. Would appreciate some thoughts from some of you experts on how to get the speedo reading to be more accurate. Thanks for any help, Don.
#130619 04/08/2005 3:16 PM
#130620 04/08/2005 11:01 PM
Get down to your local Chevy dealer and find the oldest man in the parts room. Come armed with tire size and rear end ratio and he will be able to come very close to the right color gear for the transmission. Even if he misses chances are he will take it back and trade for another one. Good luck Richie Z
#130621 04/09/2005 1:18 PM
That much off you might not correct with driven gear alone. The Speedometer Shop on the Links page has ratio adapters available. Mine works fine.
#130622 04/09/2005 1:31 PM
Thanks Joe and Richie for your responses. I will check the TCI web site and Chevy dealer but probably will have additional questions later. Thanks again, Don
#130623 04/09/2005 1:33 PM
Just saw your reply Chuck, thanks, will check out your suggestion. Don
#130624 04/11/2005 11:31 PM
Riding in the Passing Lane
Pull the driven gear out of the trany where the speedo cable goes in. The number of teeth is written on it. Get a gear with 2-3 more teeth & install it. Run down the freeway & match the odometer reading with the mile markers. Change the gear with different teeth to get pretty close to the same tenth of a mile. smile
1972 Chevy c10 Cheyenne Super
#130625 04/12/2005 10:46 AM
I checked with The Speedometer Shop about a ratio adapter and they will build me one for about $90 + shipping. That would be the easiest way to go but I'm interested in what Wrenchbender suggested. After unscrewing the speedo cable how do you get the gear out?
Thanks, Don
#130626 04/12/2005 10:48 AM
I had the same problem with my 55,and 700R4 tranny set up.It was showing 60 mph at 45 mph.I took the gear out,it was a 40 tooth.Installed a 42 tooth and its right on now.
#130627 04/12/2005 10:41 PM
Take out the bolt that holds the clamp on. Pull the housing out. The gear will come out with the housing or will lay right inside. You probably will want to replace the seal inside the housing & the o-ring around the housing. There is a little ring holding the seal in it pulls out real easy with a hook tool. smile
#130628 04/13/2005 12:45 PM
Dale and Wrenchbender, thanks for the info. I will see if I can get the speedo gear out and check the number of teeth. I was thinking about this yesterday and I thought that the number of teeth on the gear would need to be increased by the same percentage that your speedo reading was off. In other words, if your reading was off by about 30% then the number of teeth on the gear would have to change by that same percentage, such as going from 40 teeth to 54 teeth. My thinking was sure screwed up on that one. Much thanks again for your responses. Don
