1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | On my '49 AD do you find the center line with the wheels hanging or sitting on the ground? or dose it matter? the way I did it was got it all level with the wheels hanging from the frame (my jack stands were just under the cab) then I leveled the hub on two lug studs then clamped it in place to keep from moving. Then found the center of the hub. Then I placed a long streight edge across the frame. Then place the level vertically on the mark on the hub got it level and butted the streight edge to the level and clamped the streight edge. Then did the same on the other side and made my marks. I came up with 21 3/16 inches from the longest tip on the frame. the outside end is longer then the inside. I measured from the outside. Did I do this correct??? And is the 21 3/16 about correct???? I read Boyo's info on his and he came up with 20 19/32 inches. Thanks!
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | I'll tell you this, I wouldn't mount it in permanent till I had the front sheet metal on and stood back to look at it. I did all the same measuring on mine when I put the clip on. I trial fit the sheet metal and the wheel looked like it was back some. I'm talking VERY little but it looked like crap. I cut loose the clip (it was jsut tacked) and moved it forward about 1/2". It looks great now, and if there is anywhere you want it is forward too much, instead of back too much. Some times the eye is more important than the measuring tape.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | I took my center line from the straight axle,I used a small torpedo level and placed the edge of it center of the axle with the top of the level touching the frame above, when the bubble is center make a mark on the top of the frame, this is your center line, if you then use a square with the edge of the square on the frame you can draw your line accros the top of the frame from your mark you made with the level. I did it this way to install my Fatman mustang 2 crossmenber and it came out dead nuts.........looks great......
1972 Chevy Cheyyenne, 1959 Chevy Apache
