0 members (), 126 guests, and 2 robots.
Topics128,195
Posts1,057,374
Members48,469
I have a 1950 4100 with 2400 original miles on it, and need to buy 6 new tires. 3 of the rears appear to be original US Royals in a 6.50-20, and the fronts are some maybe 30 year old Co-Op 7.00-20. I cant's decide whether to stay with that setup, or just make all 6 tires 7.00-20's? The staggered setup I have works okay, and look right. I like the 7.00-20 on the front, but a bigger rear might not? Also looking for a place in easy driving distance to pick up tires near NE Iowa, and maybe get mounted? I wish there was a better modern setup all together for these old trucks, but there are no great options, and it looks like it will be $2000 plus no matter what. dang
Riding in the Passing Lane
Lots of time you cant put wider tires on the rear of those trucks as the can rub against each other.
When new they had the same size front & rear.
George
1972 Chevy c10 Cheyenne Super
You might have a hard time finding 7.00x20 tires, but 7.50x20 are available from Chicago Tire and they deliver...
http://chicagotireinc.com/7.50-20-tires-Advance-Samson-10-PR-tire/
About $1000 for 6 tires...
Any good truck tire shop can mount them for you.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Actually when new they always had larger size tires on the rear. I know this is true for the 47-54 models. Example, if it had 7.50/20, on the front, it would have 8.25/20, on the rear. If i were you, I'd run 7.50 front, and 8.25, on the rear, if you have the clearance. The larger tire size will help your rpms.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
7
7 Offline
Just my two cents, I would run the largest you can with all 6 being the same, you have a lot more options when it comes to tire rotation and also if a tire is damaged beyond repair you have a spare already on the truck without having to worry about which position you are going to try to match. My experience is from owning three Chevrolet dual wheel pickups over the last 40 years and with my '57 5700.
I think I am going to try the Samson tire in a 7.00-R20. It is a radial, with 14 ply and probably heavier duty than what I need. I like the idea of radials though, but have no clue how they will do? Looks like a good tire for $190 ea. 6 tires, with flaps, and tubes delivered for $1250. I plan to order them on Monday, unless I hear a reason not to?
Crusing in the Passing Lane
Since you have the GM 5/10 wheel bolt pattern, the first tubeless tires were put on tubeless rims with that bolt pattern. Many were put on farm trucks in the late '50's. It might be worth looking around for some of those tubeless rims, even if you can find a pair to start with.
Ed
Nebraska Tires
These guys usually have a good selection
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
