0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#1305505 04/01/2019 1:19 AM
I have a 1960 235, having problem that intake gasket to small to fit over intake alignment rings.
Any help would be appreciated, Part numbers ?
ed54 #1305573 04/01/2019 5:17 PM
Sounds like you have the wrong gaskets, perhaps for 216?
BC
1960 C60 pasture art
ed54 #1305591 04/01/2019 7:47 PM
I think BC59 is probably spot on. In addition to the stock type intake/exhaust gaskets, you might also want to consider the one piece Rimflex gasket. Excellent, really excellent in sealing the intake/exhaust.
http://catalog.remflex.com/CHEVROLET_GM_CHEVY_Header_Exhaust_Manifold_Gasket_p/2027.htm
Mike
ed54 #1305836 04/03/2019 8:35 PM
The Rimflex are a little pricey, but I just installed one on my 261, seems like a very solid fit. I've also heard using 2 paper gaskets is acceptable if the mounting surface has not been machined perfectly flat.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
ed54 #1305860 04/04/2019 12:00 AM
Patrick,
My guess is that by "paper gasket", you are referring to the standard manifold gasket (metal over thick material)?
https://www.classicparts.com/1947-62-Manifold-Gaskets-235-CI/productinfo/80-405/
ed54 #1306115 04/05/2019 8:52 PM
get the remflex you will never regret it. We used every conceivable type of gasket and/or sealer for the generators I worked with in alaska, Then remflex came along, and my whole life changed.
