3 members (TUTS 59, Jon G, Joe H), 97 guests, and 3 robots.
Topics128,026
Posts1,055,402
Members48,422
#1305624 04/02/2019 12:34 AM
So I saw something that I really liked on a 350 and I would like to use it in place of the top alternator / generator bracket. I am attempting to find the best turnbuckle to use on my 216. If anyone has any ideas as to where to find a good looking looking turnbuckle?
Chris
ndkid275 #1305635 04/02/2019 1:18 AM
I thought that was a neat idea too when I saw one.
Then I thought how often do I adjust a fan belt, and how difficult is it with the standard bracket...?
1952 Chevrolet 3800 pickup
---All pictures---
ndkid275 #1305648 04/02/2019 2:32 AM
I thought it would look good, easy to tighten or loosen a belt, and faster to replace a belt on the side of the road. The standard bracket also wobbles a bit.
ndkid275 #1305653 04/02/2019 2:57 AM
Check out McMaster-Carr for turnbuckles. They have a good assortment so your should be able to find something that would work.
ndkid275 #1305654 04/02/2019 2:59 AM
Thank you!
ndkid275 #1305657 04/02/2019 3:22 AM
The ends of that part are commonly referred to as a heim joint ends. The Navy calls them circulating ball ends (at lest that is what my buddy Squid tells me). They are much better than a regular turn buckle.
Carl
ndkid275 #1305659 04/02/2019 3:27 AM
McMaster has heim joint ends as well, both left and right threaded for use with turnbuckle bodies.
ndkid275 #1305665 04/02/2019 4:59 AM
I will have to look up the tread pattern that I need for alternator on one side and thermostat housing bolt on other.
ndkid275 #1305669 04/02/2019 5:31 AM
You just need to know the diameter of the bolts that will go thru the eye on the heim joints. Since nearly every bolt on a Chevy takes a 9/16" wrench, that would make them 3/8" diameter. The threads on the heim joint shaft need to match the turnbuckle body.
ndkid275 #1305697 04/02/2019 1:55 PM
I'm using turnbuckles as replacements for my rear fender struts. I can easily make tire to fender gap adjustments and then readjust as I change tires. True Value hardware stores have a large assortment.
ndkid275 #1305739 04/02/2019 9:47 PM
Yet another case of "if I don't understand your reason, your statement is wrong".
ndkid275 #1305742 04/02/2019 9:59 PM
If the alternator pivot is restricted from movement not parallel to the rotor, then heim joints would work OK. But you're right, they would introduce some potential instability. But a standard strap type adjustment isn't that much better as far as keeping the alternator aligned.
ndkid275 #1305755 04/03/2019 12:00 AM
Don't forget, left hand/right hand threads on the link, for however you do it.
panic #1305771 04/03/2019 1:04 AM
Originally Posted by panic
Since the attaching bolts are exactly parallel, use of Heim joints, especially in compression, is called "a mistake": you're adding a misalignment where none existed.
Can you expound on this a bit? I don't follow your reasoning. I used to have long hair, so let er rip. I'll just read it slow.
Carl
ndkid275 #1305782 04/03/2019 2:03 AM
Carl,
Is it because it allows it to swivel slightly?
Chris
ndkid275 #1305783 04/03/2019 3:15 AM
Carl,
Chris
It would be able to swivel if the pivot point were a single short bolt. But they're usually about 3 or 4 inches long, which restricts the movement only around the bolt. With the turnbuckle perpendicular to the axis of the pivot bolt on the opposite end of the generator/alternator. It can't move sideways. It's all about restricting the degrees of freedom. A long bolt takes care of two directions, and the third is taken care of by the turnbuckle or the standard adjusting strap.
