1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
Page 1 of 2 1 2
#1233909 09/08/2017 12:44 PM
So from everything that I've read on here, it seems that after you drain it, you take the side plug out and fill until the fluid reaches the hole and put the plug back in. Just looking at the position of the side plug to the bottom of the trans, there's not a whole lot of fluid going in. The manual says 1.5 pints of fluid should go in, but that's for a 3-speed. It states a 4-speed needs 6 pints. Is there a different way to fill the 4-speeds? I can't see 6 pints going in from this plug....
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
Riding in the Passing Lane
Yes. You fill it to the pipe plug on the side of the trans. A 4 speed truck trans. SM 420 or SM 465 will hold almost 6 pints. (3 qrts).
1972 Chevy c10 Cheyenne Super
If you have a SM420, just remove the shifter and pour the gear oil in from the top of the transmission.
Lots more pictures
Is pouring from the top better? Or just easier?
More images
Crusing in the Passing Lane
Easier, if one discounts fooling with the cover, shift forks, gasket, floorboard, etc.
Ed
Uh, ok... side plug it is!
More images
I think he was talking about just popping the shifter out and pouring it in the hole. No need to disturb shift forks or transmission cover.
I would suggest that you fill it to 1/2" below the side plug hole. that is the level I fill mine to. The fluid expands as it heats up.
1951 1 Ton Completed
Thanks for the post, truckernix
You can pop out a shifter faster than crawling under the truck and removing the filler-plug, and usually avoid spilling oil when filling from the side. You do have check for the height of the fluid as you near the side plug hole.
Wouldn't you have to crawl under and remove the filler plug anyway to check the level?
1951 3100
Yes,"You do have check for the height of the fluid as you near the side plug hole."
Or, put in the recommended "measured" amount: 6 pints. That amount is still perhaps not "exact" due to the transmission fluid being shared with the enclosed driveshaft u-joint housing/cover (which does not drain, but it usually drips continuously). dang
I worded my question poorly. Was trying to ask if there was a way to eyeball the level from up top, or if you had to get under the truck either way.
1951 3100
You worded it just fine, JW51
There is no easy way to eyeball the level from the top.
You would have to get under the truck to see if it is near being filled to the hole.
"Yes,"You do have check for the height of the fluid as you near the fluid nears the side plug hole."" (sorry about the lack of clarity)
Nothing like enjoying the aroma of hypoid fluid on a warm summer day, especially if it lands on your coveralls!
Yes that is what I meant...it would be the only method that would be reasonable, way easier than messing around under the truck. I agree on the 1/2 below the drain plug hole otherwise you may seep gear oil on the clutch when descending steep slopes.
Lots more pictures
So kerosene flush still the way to go? Should this be a full 6 pints? Or less? Can I still use it in my heater this winter afterwards? smile
More images
So how much kerosene to flush a trans?
More images
I used about 1 litre or so when I flushed out mine. I removed the side cover/ pto and sprayed all around inside using a parts sprayer. With the drain plug removed and catch pan under to catch flush fluid I was able to analyze the fluid for fillings and debris.
With the pto reinstalled I then refilled through the top using about .5 litre more then the recommended amount to a account for the pto the level is about 1/2 inch below the filler plug.
FYI I would not use in your kerosene heater with out running through a filter first it was pretty nasty!
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Thanks Doyle - Did you try running it at all with the kerosene in it? I've heard that pouring it in and idling for a few minutes will help clean it out. I'm just wondering if a full litre is the right amount for this.
More images
No I didn't try to run with just kerosene in it, I don't think in my case that was required due to fairly low mileage and I had good access through the pto side of the transmission to spray and flush out the remaining old oil and sludge.
I can't really say home much would be required to do this but would assume you would need to fill as per specs, maybe even do it a couple of times.
I've flushed and run a transmission with diesel fuel, fill it up to normal level and remove driveshaft so no load while running it.
https://www.stovebolt.com/ubbthread...ve-improve-drive-repeat.html#Post1138446
1952 Chevrolet 3800 pickup
---All pictures---
Sorry, I know this is an old post, but I didn't get around to flushing the tranny last year, so it's on the list for this Spring. I just wanted to see if it was necessary to drop the driveshaft to flush the tranny with kerosene? I just know that I may end up bustin' bolts or something to do this and I'd rather just do a flush for now. I did pop the shifter off last night, so it'll be an easy pour to get the fluids in, which is nice.
More images
I personally think you can flush it in neutral, with the engine running. The clutch gear will be turning-as well as the front mainshaft bearing and clutch housing needle bearings, which turns the counter shaft assembly which in turn turns the front and rear bearings on counter shaft, the constant mesh gears on the main shaft, so second and third gears will be rotating on the main shaft. The only thing not moving is the reverse idler and the first/reverse gear and main shaft as well as the rear main shaft bearing, but they will get washed from the whirlpool going on in there. On 1/2 ton trucks I would not recommend this method on enclosed driveshaft because with no seal in the back other than the driveshaft you will wash fluid down into the rear bell u-joint area.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Thanks sstock, any idea how long will be enough to flush it out?
More images
I bet 5 minutes of agitation would be enough to clean it out. Then buy 90 weight mineral oil found at NAPA for about 15 bucks, put 6 pints in and run it for a day or so then drain it out and refill with 6 more pints of the mineral oil. Should be nice and clean then.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Is it really necessary to flush it? I cringe on the idea.
Craig
cmayna - I really have no clue, I don't know what maintenance has ever been done on it. I just want to do what I can to get it performing as good as possible.
More images
Goach, you might remove the pto cover on the driver's side and drain the old stuff out of there and then try and get a popcicle stick and try and reach in and get all the sludge out first before washing. The later sm420s say 61 and newer have a round magnet instead of the chip collector at the bottom of the case.
Option B would be buy a complete rebuild kit around $115 disassemble the trans, clean the case properly, replace the 2 bearings on the main shaft, two on the counter shaft, thrust washer next to 2nd gear and synchros on 3rd and 4th if needed and clutch gear needle bearings. They are not that bad to work on but you need a press. You have to get everything removed to get to the Chip collector to remove and clean. I have found on two occasions the retaining ring for the second gear syncro laying in the chip collector all mangled and broken up in pieces.
Here is a guy with that problem and doesn't know it yet, but will find his retaining ring in the bottom of his transmission:
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Thanks sstock,
I do want to do a full gasket change/rebuild on this, just can't put the time in at the moment. I am hoping to get to it with a gear swap next winter, if I can finish up some other projects on the go. I can't go the summer without my truck though wink
Any reason why a kerosene rinse might be a bad idea?
More images
No cant think how it couldn't but help to clean things up, idling in gear, no load though, wheels up, or idling in neutral like said before
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Probably a stupid question, but does the shift lever need to go back in to idle in neutral? Or will this cause damage/make a mess?
More images
No it doesnt, shouldnt get too messy
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
So, just cleaning up the area around the drain/fill plugs and before I get too far I wanted to post this pic to see if anyone can tell me where this is leaking (based on the damp areas of grease) and possibly which gaskets will need to be replaced. I'm not quite ready to drop it and rebuild, but I'd like to get my supplies ready for when I do.
https://photos.app.goo.gl/GaRto8NiLbutUKR79
More images
Couldn't open px, however here are only a few places besides the top: input shaft, rear seal, front retainer bolts loose, drain plug of course, crack in case-very unlikely.
Ed
Not sure if that's better, never had a problem with these links before.
Kerosene has run through and just letting it drip a bit before the SAE 90EP API GL-4 goes in...
More images
I dont think I have ever seen a trans this dirty,lol. I would knock some of that grease and crud off of it first before cleaning the inside. There are 5 gaskets on this trans, the top loader, the front bearing retainer, which you cant get to unless you remove the trans. The rear bearing retainer, which you can replace if you remove the rear ujoint housing and u joint, this one is what is leaking by the looks of it. The PTO cover is the 4th gasket. The fifth is between the rear bearing retainer bell and the mounting retainer of the universal ball. There is a cork seal on the universal ball and slip joint bell flange at the rear of the ujoint as well as a small cork seal on the small end next to the torque tube. Knock some dirt off of it and it will come into focus better.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Thanks sstock, that's a good list for me to go by. Would a '5-gasket' set normally carry all the requirements that you listed?
More images
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
I'm going to bring life back to this thread, since it's mine anyway wink
I have two SM420's, one that's in and original to my '48 and one that came out of a 56ish truck. I'm looking to go through and refresh one when I do an engine upgrade.
Question is, how to determine which one is in the best-shape to use?
Thanks!
More images
Well, you know how the one you are using, so you will know what parts to replace, synchros are the biggest wear items that are hard to determine wear on. Shafts are easily inspected, bearings are cheap and easy to replace.
Ed
Got some numbers off of them. The original is a 591665 and the spare 591953. From what I can tell, no difference in these two model numbers.
Anyone know of a decent resource to identify synchro wear, or what to look for with shaft/bearings?
More images
Page 1 of 2 1 2
