3 members (DadsFirstPickup, 1955 1 Series, Oswald), 110 guests, and 1 robot.
Topics128,047
Posts1,055,622
#1305298 03/30/2019 4:41 PM
I've been trying to install my original SS exterior trim into a Steele front windshield gasket without much luck. I've got the glass installed on both sides and the assembly is lying flat on a table. I can get the outside with corners in but am struggling to complete the two inner ends into the pillar. Is there one method that works better than another? Should I attempt to slip the two ends in first up against the pillar, then proceed to the outside corners? I've been spraying it with soapy water also.
Has anyone else had issues with this?
'48 3100 Chevy
Well I think I finally figured out what my problem was! Evidently when the new "Steele" gas was bonded at the ends with the rubber gasket of the pillar there wasn't quite enough room to adequately install the SS trim. So to avoid gouging into the gasket to modify it , I slightly modified the ends of the SS Trim. Here are a few photos showing the small angle I cut off with a dremel. Fit is great now or I should say as good as it's gonna get!
Former BMW Rider
Former BMW Rider
Nice work Jeff! Let's see a pic with the windshield installed!!
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Looks factory. Nice work.
1951 Chevy Panel Truck
Thanks Andy & Miracle, one step at a time. I imagine some time this week or next weekend I'll attempt the complete installation!
Timely subject. My truck did not have the trim installed when I bought it and I've debated a couple times trying to install it without removing the windshields. Any words of encouragement.... anyway to do the job with the windshields inplace?
RonR
1970 340 Duster
1964 CJ5
Moparguy
First you'll need the proper gasket for installing the SS Trim. Steele Rubber sells both gasket/seals for the front windshield. One for using SS Trim (deluxe) and one without the trim.
https://www.steelerubber.com/search...odel=3600-truck&style=2-door-flatbed
I assumed you were referring to your '51 3600?
If you do however have the correct gasket installed to use the SS Trim I believe it would be almost impossible to install the trim while on the truck. Everything I have researched says
to install the trim on a flat work surface prior to installing on the truck.
Good luck and keep us posted!
Jeff
Moparguy
Whoops! darn key board
Moparguy
attached is a cross section of the proper gasket when using SS Trim
