2 members (Peggy M, Ponchogl), 52 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#1305358 03/31/2019 1:30 AM
New to me, 1956 3800. Is it typical that this truck would have been originally built with a braided battery ground to the firewall? I did spot a second braided ground from the lower firewall to the starter.Negitive battery cable
Wayne
that's the correct original setup
Thank you Bill.
Wayne
Crusing in the Passing Lane
If you don't need to be exactly original, it would be more efficient to go directly from the neg. terminal to a bolt near the starter, then to the firewall location, less opportunity for voltage drop that way. Cu is a better conductor than Fe.
Ed
EdPruss #1305453 03/31/2019 5:56 PM
Ed
Ed, you are right about the copper having better conductivity than steel. This truck I bought is so original it will pain me just to use parts that aren't labeled Delco. But of course I will have to.
I am new to this forum, but not new working on vehicles. I have been working on light and medium duty trucks since 1971. Yes I'm that old. The braided ground was engineered for a second reason. Since the battery case is plastic or Bakelite it insulates the conductors from current and heat. The braided ground was designed for heat dissipation. Hooked to the negative stud, heat then could move through internal lead and be cooled by the cable.
Of course we know engineers are not always correct.
Wayne
