| | | Forums66 Topics128,164 Posts1,056,968 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2018 Posts: 80 Shop Shark | | Shop Shark Joined: Apr 2018 Posts: 80 | I’m just installing a new temp gauge on my 49 Chevy truck. Boy it’s hard to get under the dashAny tips on putting in those 2 little screws in the back of the gauge? Thanks. | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | I lay a thin 24”x24” piece of plywood over my peddles up to the bench seat. Then crawl in from the passenger side looking up. If you have your tools and light staged where you can reach them it’s a breeze. Well....kinda.
Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | Maybe I am missing something here. I did not realize that you could replace a '49 temperature gauge without removing the whole instrument housing and taking the face off. I did not realize that the housing had a large enough opening that you could pull the gauge from the back.
Learn something every day!
Rusty
| | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | You need to remove the entire cluster, then take the cluster apart. Make sure that you don't disturb the pipe.
