10 members (SmalltownTRKGuy, Njm, Hotrod Lincoln, walter74, baldeagle, cmayna, Woogeroo, Ponchogl, 2 invisible), 348 guests, and 7 robots.
Topics128,165
Posts1,057,089
Members48,463
H Online: Content
Can anyone here recommend a business that will grind a custom cam for a 216? I'm considering doing a buildup of an upgraded 216 for some dyno testing, and I'd like to make one of the modifications a 261-style "Corvette" cam lobe. The small-journal cam cores for 216's and early 235's are getting extremely scarce, but it seems that it would be possible to use a 235 cam and simply reduce the bearing journals to 216 diameter. That would also give a cam grinder more of a lobe to modify when changing timing and lift.
Yes, one of the best IMHO Delta Cam in Tacoma Wa.
http://www.deltacam.com/
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
The only outfit I've dealt with for custom grinding is Delta Cams. Pricy, but seem to do good work. I don't know if they will do all you are asking. http://www.deltacam.com/camshaftgrinding.php
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
H Online: Content
Thanks for the reference. I might have found a simpler solution- - - - -how about turning the bearing journals down on a 261 cam so it will fit into a 216 block? My Federal-Mogul bearing catalog shows that there's almost exactly 1/8" difference in the journals (all 4 of them, even though they're different sizes) so that means taking 1/16" off the radius of the cam journals should allow a 235/261 cam to fit into a 216 block. I've got a couple of junk 235 cams, and several 216's sitting around, and it won't be difficult to fire up the lathe and the tool post grinder to do a little experimenting. If I can get a cam and a block communicating with each other, then it will be time to check on such things as piston/valve clearances, etc.
I had a horrible looking cam I sent to Delta cams in Tacoma, after talking to them they said they have a 3/4 grind that would work for me.. looked band new when it came back.. surfaced the lifters also for about $85 dollars total .. a bargain these days..
