0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1305215 03/29/2019 11:12 PM
Looking to replace the push buttons on my 1950 Chevy 3100 radio but having trouble removing old ones, any tips on getting them off? Thanks.
BobF #1305229 03/30/2019 12:39 AM
I used to use a large set of cutters or pliers and break bits off. Now I use a heat gun. I heat the plastic up until it get gummy and then remove it with pliers. I pull each one out in the setting position, one at a time while I remove them. I soak the new button in hot water before installing them.
1951 1 Ton Completed
BobF #1305545 04/01/2019 1:23 PM
Thanks truckernix followed your suggestions and they worked perfectly, old knobs off new ones on. Appreciate you taking the time to respond.
Moderated by  truckernix
