6 members (greenie-reddy, tesa, Shade Baby, asilverblazer, wvstovebolt, 50Chevy3100), 88 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#130484 12/02/2003 6:23 AM
Junior Member
Junior Member
I have a Chevy SB 350 and installed a Edelbrock 650 CFM carb with a performance intake manifold with a slightly higher performance cam than a stock cam.
I started the engine the first time and was able to set a timing that allowed the engine to run during the break-in period (20 minutes at various rpms between idle and 2500).
What do I do now to get a good initial timing? Based on the vapor in the exhaust, it appears that I the air/fuel mixture is very fuel rich.
What suggestions do you have to set the timing for this motor? How do I go about adjusting the carb to eliminate fuel waste? Thanks!
Richie West
#130485 12/03/2003 10:38 PM
My edelbrock was set pretty rich out of the box. I remember I had to change springs and things to get it right.
If u dont have the instructions for the carb contact edelbrock they would probably send u a set of instructions. You may also need the adjustment kit they sell.
