4 members (TexasJim50, 3B, Otto Skorzeny, 1 invisible), 66 guests, and 8 robots.
Topics128,013
Posts1,055,322
Members48,419
#1304643 03/26/2019 12:15 AM
So I just got this 1956 3800 pickup and I have a lot of questions. I'll start with just a few.
What size is the engine? I was reading through some posts about size and numbers on parts but I'm still not sure. On the head is a casting number B60 848. On the block lower edge by the distributor, stamped numbers 033125IF5bXB. I guess the lower case "b" could be a "6".
Then a part number for the oil filter and what weight rating for the engine oil was recommended for this engine.
Wayne
Turbo4whl #1304715 03/26/2019 4:00 PM
More than likely a 235.
If you look just above the starter, are there 2 vertical bars stamped into the block? If so, it is more than likely a 261.
Also, there should be an engine ID stamped into the block by the fuel pump. Take a few pictures of that side of the engine and post them, you'll get some better assistance.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Turbo4whl #1304719 03/26/2019 4:17 PM
Post the codes from the locations shown on this page.
We can better help you ID your engine, with those codes.
tclederman #1304768 03/26/2019 8:50 PM
The second number I posted is on the ledge by the distributor. 033125IF5b XB This is a stamped in number, not cast. Located the same place as the green painted engine in the link you posted. I will look for more numbers.
Wayne
Turbo4whl #1304827 03/27/2019 3:28 AM
Tim, He did give us the engine serial number...
033125IF5bXB
033125I = Unit number starting with 001001
F = Flint
56 = year
XB = 3800 235
Looks like you still have the original engine!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Turbo4whl #1304832 03/27/2019 4:17 AM
Mike B, Thank you.
Wayne
Turbo4whl #1304843 03/27/2019 11:44 AM
Yes, thanks, Mike
But, I like to also see date casting codes and the head casting code.
The stamped engine serial number can be changed, and heads seem to be commonly changed.
