All, Need help with this. Took a fieldtrip to a buddies garage. He is working on a 63 C10, SWB, Stepside. I wanted to compare his frame number to the VIN tag. VIN tag good for 63 C10 SWB. Attached 3 pictures of frame numbers. Frame manufacture plant (S) and numbers matched VIN tag - EXCEPT - we noticed the last digit in both frame numbers was stenciled with an X, slightly faint, but distinguishable. You may be able to see it in the pictures if you look closely. Stenciled on top of the X is the # 5. In both frame locations, the number 6 was stenciled below the last digit, also noticed in the photos. The VIN tag is 6c144S159446.
Is there a plausible explanation? Can we conclude it was friday afternoon and the stencil man was ready to go or is there something more interesting?
~ HB 1966 Chevrolet K-10 | Ghost: formerly Flappy Fenders | In the Stovebolt Gallery 1962 Chevrolet C10 1962 Suburban
Looks like he caught his mistake and X'd out the 5 and placed the 6 underneath, makes sense and probably happens more frequently than you might think. Humans making mistakes.
1953 Chevrolet 3100 261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY Gallery Video of the 261 running
1964 GMC 1000 305 Big Block V6, sm420, the next cab off restoration
I believe the x was stenciled first and the more pronounced 5 on top of the x. I have not seen many frames, but is this wicked weird or just something that occurs from time to time? Has anyone seen this previously?
Can you tell by height, width and style that the X and 5 came from the same letter set as the rest? If the X was under the 5. I don't see how someone could accidently put an X there first? I have to go with the 5 is under the X.
I also can't believe that someone nefarious would ever do that. That's a straight out factory stamp job. Not a PO vin changer. A billion to one chance of finding a frame that is one number off of the VIN and changing it........or vice versa.
There is evidence on the internet of factory errors on Ford sites. One explanation, other than Friday afternoon in the 60's in CA bong land, is that stamp users mixed up the location of stamps within the set. The next guy pulled a 5 out of where the 6 was supposed to be. I don't know what kind of stamping tools were used in 63.
