10 members (SmalltownTRKGuy, Njm, Hotrod Lincoln, walter74, baldeagle, cmayna, Woogeroo, Ponchogl, 2 invisible),
348
7
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | 51 Chev. PU 3100 foot engage parking break won't stay engaged. Push the foot brake pedal, brake engages, then remove my foot and the pedal releases without pulling release handle. Had been working fine. Any suggestions to keep the parking brake engaged until I pull the release handle? Thanks, Tex Chev. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | TexChev. Perhaps the flat bar that locks against the pedal rod had rounded edges in the hole the rod goes through? 4.603 LOCKDo you have 4.597 SPRING? | | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | Do have the 4.597 Spring and 4.603 lock. I'll check the flat bar that locks against the pedal rod. Many thanks, TexChev | | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | Sometimes the brake release rod (the one with the T handle) gets bound and won't allow the brake pedal to lock. Remove that rod and see if the brake will lock. Carl
| | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | 52 Carl, do you mean by "bound" that the brake release rod cannon be moved? The brake release rod on my truck is free and travels back and forth moving the 4.603 lock bar. Thanks, Tex Chev | | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | TCLederman wrote -Perhaps the flat bar that locks against the pedal rod had rounded edges in the hole the rod goes through?
The flat bar that locks against the pedal rod appears and the hole the pedal rod goes through appear to be normal. No abnormal wear, etc. Tex Chev | | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | 52 Carl, do you mean by "bound" that the brake release rod cannon be moved? The brake release rod on my truck is free and travels back and forth moving the 4.603 lock bar. Thanks, Tex Chev Does the release rod allow the lock bar to fully move to the locked position? Removing the release rod will confirm this. Carl
| | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | Reply to 52 Carl, the release rod does allow the lock bar to fully move to the locked position.
Reply to TCLederman -After looking more closely at the hole through the lock bar that locks against the pedal rod appears that probably is the problem. Any suggestions on how to modify or rework that hole so it will engage and hold the pedal rod? Should I make the hole more oblong or elongated? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | So you have disconnected the release bar and the lock bar still does not engage?
Ed
| | | | | Joined: Jan 2019 Posts: 5 New Guy | | New Guy Joined: Jan 2019 Posts: 5 | My Parking Brake Release Rod is missing the spring identified in the parts manual as 4.597 which is very confusing because they use the same part number 4.597 for the spring which is on bar 4.603. These cannot be the same spring? I am referring to the link provided by TexChev I have found the 4.597 spring online to purchase but it looks like the one that I have on the bar 4.603 and I have not found one that looks like the right one to go on the release rod? My brake holds sometimes but not always I assume this spring would fix that. I may just go to my local ACE Hardware and try out several different springs that fit over the release rod? | | | | | Joined: Mar 2010 Posts: 10,307 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,307 | I noticed that part number duplication too. It must be a typo.
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Old online Chevy manuals has many springs listed in section 4.597. The ones you need are: p/n 3695565, locking, 13/16 ID x 1 1/8 long. and p/n 3687152, anti-rattle, 9/16 OD, 4 coils. I measured the ones on my 49 3100 and those are approximately the sizes of my springs. Hope this helps. The Old online Chevy Manuals website has a wealth of information!
Ed
| | | | | Joined: Jan 2019 Posts: 5 New Guy | | New Guy Joined: Jan 2019 Posts: 5 | thanks went to Ace Hardware looked at several guessed and purchased a couple ones. Installed one on the release bar working great now. The one I used is smaller diameter but about 1-1/8" long. | | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | Forty 9 wrote; So you have disconnected the release bar and the lock bar still does not engage?
I have. Have talked to a 51 owner who says the hole in the lock bar can become worn and his solution is to change the angle where the lock bar engages the brake. Haven't tried it yet but definitely on my list of things to attempt. Appreciate all the info. and one I solve the issue will post what I've done. Thanks again and regards, Tex Chev 51 | | |
