BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,776 Posts1,039,259 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Mar 2010 Posts: 295 'Bolter | 'Bolter Joined: Mar 2010 Posts: 295 | [img]http://[/img]8595.jpg Anyone have a wiring diagram for a Signal-stat 900 sigflare turn signal switch?
This is no longer fun
| | | | Joined: Jan 2013 Posts: 1,518 'Bolter | 'Bolter Joined: Jan 2013 Posts: 1,518 | 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | Joined: Mar 2010 Posts: 295 'Bolter | 'Bolter Joined: Mar 2010 Posts: 295 | Thanks STEVE where did you find diagram ? I can’t zoom in on it too much hard to read As soon as I find out where the blue wire is hooked up to I should be good to go.
| | | | Joined: Jul 2000 Posts: 2,115 Insomniac | Insomniac Joined: Jul 2000 Posts: 2,115 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | Joined: Mar 2010 Posts: 295 'Bolter | 'Bolter Joined: Mar 2010 Posts: 295 | Thanks I was able to screen shot a pic of the diagram ðŸ‘
| | | | Joined: Mar 2019 Posts: 23 'Bolter | 'Bolter Joined: Mar 2019 Posts: 23 | You may have figured this out, but the blue wire runs from the third prong on the three prong flasher to the pilot light on the 900. Wayne | | |
