| | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 30 Member | | Member Joined: Jun 2000 Posts: 30 | Well now I went and did it. I've started my second 'bolt project. Most here will hate me but I am putting a '51 bolt onto a 1997 S-10 chassis, I bought a wreck for $500 complete with 97,000 mile. The wheel base is within .5" I plan to turn my 14 yr old kid loose with it when he is 16 so I need something reliable with good gas mileage. Started tearing the S-10 down to chassis last night...sold the salvageable front clip for $100 so now I have $ for floor-dry and de-greaser. | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Nope-won't call you that! WILL, however ask you to post your progress...there's been a lot of discussion/interest in this topic here. Pix would be good too! Is this a 2WD S-truck? If so, you might want to swap out the original rearend for something a tad wider, cuz they're too skinny for an AD. Try a '70's Camaro or maybe a 4WD S-truck (3" wider than 2WD). Best of luck and keep us posted. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Aug 2001 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 78 | Just a thought on the S10 thing. I was recently at a car show here in saskatoon and a guy had a custom extended cab '46 chevy half ton on a S10 chassis. I asked him about this due to the amount of negative feedback I'd seen on this board about S10 frames. Anyhow, he said ALL the body mounts except for 2 lined up with his 46. He didn't elaborate, but I'm guessing the extended cab had something to do with that. By the way, he cut up 6 cabs to make this extended cab, nearly made me cry. Beautiful truck though. Somethin' to think about.
----------------------------------- Rollin' Hard 1946 Chevy 1/2 ton 1959 Phord 1/2 ton 2001 Chevy 1/2 ton
