| | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | Will someone recommend a good donor vehicle for behind the rear axle poly fuel tank for my 1956 3600 truck? Im trying to keep costs down so I prefer finding one at a local salvage yard. I already have a side mount for the spare. Thanks | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | For a while I used a modern Chev pickup tank that mounted inboard of the frame, (some pickups have two of these one on each side) worked great as long as you can rig up a filler neck. Not what you asked for but worked great for me.
| | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | I think Mike B put an S10/Blazer tank in his TF. It runs along the frame rail, not behind the rear axle. I couldn't find the thread but you can search for it or contact him.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I used a factory 55-59 Suburban/Panel fuel tank that mounts between the right frame rail and the driveshaft and plumbed the filler neck back to the right rear fender behind the tire. Mike B  | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | | | |
