3 members (Guitplayer, 2Wheels, 1 invisible), 161 guests, and 3 robots.
Topics128,196
Posts1,057,395
Members48,469
Rusty Nuts
Rusty Nuts
Will someone recommend a good donor vehicle for behind the rear axle poly fuel tank for my 1956 3600 truck? Im trying to keep costs down so I prefer finding one at a local salvage yard. I already have a side mount for the spare. Thanks
For a while I used a modern Chev pickup tank that mounted inboard of the frame, (some pickups have two of these one on each side) worked great as long as you can rig up a filler neck. Not what you asked for but worked great for me.
1946 1/2-Ton Chevy
V
VEW Offline
V Offline
I think Mike B put an S10/Blazer tank in his TF. It runs along the frame rail, not behind the rear axle. I couldn't find the thread but you can search for it or contact him.
~ Victor
1957 3100 - moved on
We use the 21 gallon Blazer tank because it's plenty narrow enough to fit between just about any frame rails and has a left side filler tube. Mustang fits good but the filler position sucks. Pics of a Blazer tank in an AD with a motorcycle pop up gas cap which is nearly invisible if painted body color.
[img]https://i.postimg.cc/PvQgq9Qj/003.jpg[/img]
[img]https://i.postimg.cc/1nJThwmm/004.jpg[/img]
[img]https://i.postimg.cc/YGZ6WC8N/008.jpg[/img]
Evan
I used a factory 55-59 Suburban/Panel fuel tank that mounts between the right frame rail and the driveshaft and plumbed the filler neck back to the right rear fender behind the tire.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Rusty Nuts
Rusty Nuts
Thanks everyone!
