| | | Forums66 Topics128,052 Posts1,055,770 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | Hello fellow bolters....
Its been quite a long journey working on this 55 chevy 3600 with my boys. Since minor and major disassembly on various parts of the truck, I have misplaced a few parts here and there.
One of the pieces we are in need of now is the throttle linkage from the accelerator pedal to the carburetor.
I know the original motor was a straight 6 inline engine, I reckon that linkage left with the motor. Since we now have a small block 350 engine in its place, I have nothing to work the carburetor from the pedal.
Any suggestions as to what you may have done or have used to fix this? Thanks, Brian, Grant and Spencer
1952 GMC model 473 dump truck 1951 Chevy 1500 stepside
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Hello fellas, Not sure if you are on a tight budget or not but here is LMC’s fix to your problem. If you want an original piece I’d suggest a boneyard somewhere. http://www.lmctruck.com/icatalog/ca/full.aspx?Page=106PN- 32-4544 for a 1955-1959 265/283 task force V8. | | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | Fox,
Got the LMC piece you referenced.... But its a pretty tight fit and lookss more like a universal piece to be alteres to your particular vehicle...
I guess its time to start callin around to junkyards... 😔
Darn.... Brian
