8 members (rfs56trk, Frank50, BarryP, Gazz, UtahYork, Jon G, Ole49GMC, 1 invisible),
106
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 35 | Hey all, slowly begging the process of swapping out my original axle to a P30 in order to get the benefits of disc brakes and easier to find replacement parts. The one thing I am uncertain on (or really just want to double check) is if this is the correct axle.
Do I have the correct understanding in that my stock rims will bolt to this spindle after increasing the center hole diameter?
https://www.heavytruckparts.net/detailview.php?partnum=3563&vendor=2251343&store=1&oemnum=P30&partname=Axle-Beam-(Front)&make=GM&model=P30
Why bring a gun to a knife fight when you can bring a howitzer?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Looks right, what little I can see of it.
Correct on the wheel center hole being larger for the newer axle. | | |
