1 members (Phak1), 75 guests, and 2 robots.
Topics128,060
Posts1,055,832
I have a setup with a 54 pick up with a Hydramatic transmission. Trouble is I’m trying to replace the front transmission rubber mount but things seem to have dropped where I cannot sandwich in the upper layer of rubber, have you experienced this and did you if so did you find a solution. Should’ve mentioned I have already replaced the front engine in the middle engine rubber mounts
Thanks Todd
I’ll check this out on my truck, tommorow or Friday.
I’ll post a few photos.
